I think I'm going with 18x9 +35. It isn't a wheel with a lip so I won't have to worry about that with the +35 offset. And that way I can really dial it in with a spacer.
wheels with alot convex will clear but they wont really be wide, Like with some enkei wheels.
the rpf1s 18x8 +35 clear, but 18x9 +35 dont, the 9s make the spokes loose their curve haha
That site on Ebay has tons of great looking wheels all under $500 for the set plus $100 shipping. But no brand name? Are they going to crack in half on new england pot holes? I found a set of 5x110 Varrosten look alikes for $600
if you put a 5mm spacer on the front it will likely fit over brembos, if not you may need extended studs and a bigger spacer. with an offset like that you have room to work with.
http://www.ozzytyres.com.au select Holden Astra 5 lug
