sorry guys but i get too into photoshop haha
http://www.flickr.com/photos/chadkreiling/6790395487/http://www.flickr.com/photos/chadkreiling/6790395487/ by http://www.flickr.com/people/chadkreiling/, on Flickr
http://www.flickr.com/photos/chadkreiling/6790399789/http://www.flickr.com/photos/chadkreiling/6790399789/ by http://www.flickr.com/people/chadkreiling/, on Flickr
http://www.flickr.com/photos/chadkreiling/6783638687/http://www.flickr.com/photos/chadkreiling/6783638687/ by http://www.flickr.com/people/chadkreiling/, on Flickr
http://www.flickr.com/photos/chadkreiling/6783637775/http://www.flickr.com/photos/chadkreiling/6783637775/ by http://www.flickr.com/people/chadkreiling/, on Flickr
yes, send me the picture of the car you want the wheels on to chadkre@live.com or via text at 2405804692
Well you can't safely run more than a 5mm spacer on stock studs so it isn't going to get you much more flush with those wheels. I'm flush in the rear with 8.5" +35 and for your wheels to match that fitment you'd have to run a 19mm spacer and that would completely cover your studs iirc. You're outta luck unless you run adapters or much longer studs. Not sure to what length you can even safely go with wheel studs. Someone else should know. And that would only get the rear to be flush anyway. The front needs a bit more because it sinks in more then the rear.
Use this for calculations:
Wheel Offset Calculator
im running an 18x8 with plus35 all around, and very low. theres a 5mm spacer on rear but its not needed. im sure you can run those and then when you put them on ur car jus go from there with spacers til your happy
i dnt think he wants a fitment like urs or like anyones. hes jus tryin to get his car low and some decent rims.
neochrome LUGs on das vay
rrright.
and on a side note if anyones wonderong. i havent put the MB battles on yet because the balty it all taken apart in my garage. sc, intake mani, alt, ic pump, crank pulley. is all taken off. im waiting on some parts in the mail so im not tryin to push it out of the garage and down my driveway hill jus to see how the rims look... but ill def get to it. i think ima keep those rims when i sell the cress.. but idk i really like the cress i may keep it and build it..... i dnt kno what ii want to do
