Enkei LS-5 over Brembos
Old May 24, 2011 | 08:26 AM
Sweetsandman's Avatar
I've heard and seen conflicting stories. Just wanting to know if they fit.
This guy says this:
Originally Posted by vondersecks
enkeli ls-5 doesnt fit my 09 ss/tc even with 5mm spacers, wasted 370 to two day air ship them
And this thread would appear to show otherwise:
https://www.cobaltss.net/forums/comp...c-sale-186914/
I tried contacting the OP of ^^^^ thread quite a while ago (to see if he's running a spacer) but he hasn't been on in a while so I assume he sold his car and will not be responding.
Thoughts?
Old May 24, 2011 | 08:45 AM
BooSSted's Avatar
I think this pretty much sums it up. Worst case scenario is that you have to run a small spacer.
Old May 24, 2011 | 08:55 AM
^^Did you read the person I quoted before I posted the link to the thread with that picture? He said he couldn't even fit it with a 5mm. I'm just confused
Old May 24, 2011 | 09:32 AM
BooSSted's Avatar
Ya, I did read that quote. But I don't give a **** what someone says when I am looking directly at a picture of them installed over Brembos.
I guess I don't quite see where you're confused.
Maybe they need a 7mm spacer.....
Old May 24, 2011 | 09:47 AM
hunter19707's Avatar
Pete, the Falcons look better anyway! IMO.
Old May 24, 2011 | 10:12 AM
Eh...just confused because a 5mm spacer is about all I would run before wanting to get extended studs...so I'd rather not run larger than 5mm. I understand that we can see a picture of them installed...but I have no idea what kind of spacer he's running (if he's running one) as I have not been able to contact him. Just hoping there's someone else with these wheels that can chime in.
They each have plus sides. I just like the thinner spoke of the LS-5 more for some reason. But they're both super sexy. The 5 spoke options for this bolt pattern/offset are pretty limited
Old May 24, 2011 | 01:00 PM
BooSSted's Avatar
Why is everyone afraid of longer studs? They are cheap and take 5 minutes to change.
If you like the wheels, buy them and do what's needed to make them work. That's what myself and a lot of other people are doing.
Old May 24, 2011 | 01:50 PM
^^I may just end up doing that. It's not that I'm scared to do it...I'm just lazy and thought it was a more involved process than a "5 minute" job. I am getting frustrated with these Brembos
Where'd you get your extended studs from?
Old May 24, 2011 | 02:04 PM
BooSSted's Avatar
I don't have extended studs. The wheels I am getting require a bolt pattern conversion, but they should clear the brembos just fine.
You can get studs at any autoparts store. You just need to hammer them out and back in. Pretty straight forward.
Old May 24, 2011 | 02:10 PM
That's what I'd rather do But redrilling rotors..now THAT scares me
Old May 24, 2011 | 02:30 PM
BooSSted's Avatar
You can buy them already drilled for 5x114 from R1 Concepts.
Old May 24, 2011 | 02:51 PM
Holy Santa Clause ****...you just changed my life
I need new front brakes anyways...perhaps it is time to rid myself of this God-awful bolt pattern.
Old May 24, 2011 | 06:06 PM
BooSSted's Avatar
DOOOO IT!
Mongorat427 also re-drills the hubs to 5x114. You're going to need to do that as well. Either send him yours, or find another set somewhere and send them to him so you won't have any down time.
Old May 25, 2011 | 09:26 AM
I know he had a set for sale not too long ago...I'll have to check with him and see if he still has them available. THe only reason I didn't buy them when he first posted them was because of redrilling the rotors...if only I had known then about R1's offering.
Old May 25, 2011 | 11:21 AM
BooSSted's Avatar
He doesn't have them anymore. I just sent him a set to have done.
jmdubose202
Dec 29, 2015 05:06 PM
Tykuura
Nov 3, 2015 08:58 PM
Aug 29, 2015 03:11 PM
