Enkei LS-5 over Brembos
I've heard and seen conflicting stories. Just wanting to know if they fit.
This guy says this:
And this thread would appear to show otherwise:
https://www.cobaltss.net/forums/comp...c-sale-186914/
I tried contacting the OP of ^^^^ thread quite a while ago (to see if he's running a spacer) but he hasn't been on in a while so I assume he sold his car and will not be responding.
Thoughts?
This guy says this:
Thoughts?
Ya, I did read that quote. But I don't give a **** what someone says when I am looking directly at a picture of them installed over Brembos.
I guess I don't quite see where you're confused.
Maybe they need a 7mm spacer.....
They each have plus sides. I just like the thinner spoke of the LS-5 more for some reason. But they're both super sexy. The 5 spoke options for this bolt pattern/offset are pretty limited
Why is everyone afraid of longer studs? They are cheap and take 5 minutes to change.
If you like the wheels, buy them and do what's needed to make them work. That's what myself and a lot of other people are doing.
^^I may just end up doing that. It's not that I'm scared to do it...I'm just lazy and thought it was a more involved process than a "5 minute" job. I am getting frustrated with these Brembos
Where'd you get your extended studs from?
I don't have extended studs. The wheels I am getting require a bolt pattern conversion, but they should clear the brembos just fine.
You can get studs at any autoparts store. You just need to hammer them out and back in. Pretty straight forward.
DOOOO IT!
Mongorat427 also re-drills the hubs to 5x114. You're going to need to do that as well. Either send him yours, or find another set somewhere and send them to him so you won't have any down time.
I know he had a set for sale not too long ago...I'll have to check with him and see if he still has them available. THe only reason I didn't buy them when he first posted them was because of redrilling the rotors...if only I had known then about R1's offering.
