extended studs
Old Sep 25, 2011 | 03:22 PM
08_Slowbalt's Avatar
extended studs
I want some extended studs so I can run some slip on spacers. I want to know if anyone knows what wheel studs we can use.
I found these
Moser Engineering 8255 - Moser Engineering Wheel Studs - Application - SummitRacing.com
and
ARP 100-7708 ARP Wheel Studs
and
ARP 100-7701 ARP Wheel Studs
can anyone tell me exactly what I need? has anyone else done extended studs?
Old Sep 25, 2011 | 03:41 PM
wongafet's Avatar
how big are your spacers? I run 5mm spacers with the ARP 7708s whicha re the 2.5inch ones. The next size up ARP ones will be too long and stick out of almost any rims you'l run and you'll wanna cut them.
2.5s are more than enough since they are threaded the entire length unlike the stock studs which have that blank taper tip so you're really only getting 2inchs of thread.
Stock lug nuts will fit over the 2.5s, but if you have aftermarket close ended acorn nuts, you'll need to get extended or open ended nuts.
Old Sep 25, 2011 | 03:58 PM
so the 7708s will fit our cobalts? I just want to make sure the knurl will fit the 2.5in ones were the ones I was looking to run.
Old Sep 25, 2011 | 04:03 PM
wongafet's Avatar
that 7708 are the EXACT ones I'm running on my LSJ.
Old Sep 25, 2011 | 05:26 PM
troyss's Avatar
What studs will I need to run 10mm?
Old Sep 25, 2011 | 05:45 PM
wongafet's Avatar
with the ARP 7708s which are 2.5s should have enough thread for you, but I would go with the size up 7701s and just trim them to be safe
Old Sep 27, 2011 | 04:36 PM
I'm thinking about runing the 7701 and a large spacer, I'm trying to get flush dawg
Turbo Johnny
Feb 21, 2019 09:41 AM
BobWreck
Feb 18, 2006 10:13 PM
Turbo Wax
TurboWax
Jan 23, 2006 07:43 PM
Jmc007
Aug 22, 2005 08:14 PM
