fitment quesition.
Old Aug 26, 2007 | 12:19 AM
lil_kano's Avatar
fitment quesition.
think 17x9 with 235/45HR17 will fit?
or
17x8 with 225/45HR17?
both +35mm offset.
if anything i was going to put the 17x9 in the back for show only, but if it can fit in the front then there aswell. thanks for any info.
Old Aug 26, 2007 | 04:24 PM
lil_kano's Avatar
bump.
Old Aug 26, 2007 | 04:26 PM
JRelly's Avatar
should be able to fit
Old Aug 26, 2007 | 04:35 PM
lil_kano's Avatar
which setup?
Old Aug 26, 2007 | 04:59 PM
JRelly's Avatar
both should be able to fit, With that offset you shouldnt run into any problems. Remedy One is a runnin 19x8.5 in the front and 19x9.5 in the rear so if your worried about the width of the rim you will be fine
Old Aug 26, 2007 | 08:51 PM
lil_kano's Avatar
awsome...so 17x9 with 235/45HR17 tires will fit in the front and rear with no problems? i'm going to get Koni front and rear struts and eibach pro-kit. in other words i'm not going to slam it to the ground. let me know. thanks man, i appreciate it.
Old Aug 27, 2007 | 01:05 AM
JRelly's Avatar
yea you will be fine.... you shouldnt have any problems
Old Aug 27, 2007 | 04:59 AM
HunterKiller89's Avatar
youll be fine in the rear, might get a little rub in the front if you lock the steering wheel...simple solution: dont lock the steering wheel
Extreme Dimensions
Pontiac G5 Appearance
Oct 28, 2015 01:52 PM
Extreme Dimensions
patooyee
Oct 15, 2015 05:11 PM
Dustin24
Oct 8, 2015 09:15 AM
