fix a flat
Old Jan 16, 2009 | 01:16 AM
WHITE G5's Avatar
fix a flat
i got a tired thats leaking were it makes contact with the rim, io have to fill it every third or fourth day, so i bought some fix-a-flat spray wich is suppost to inflate the tire and make it stop leaking, but i says not to use on z-rated tires, should i still use it since the tire cant be repaired anyways and hope ill stop leaking?
Old Jan 16, 2009 | 01:21 AM
jlong3382's Avatar
Probably not but it's your call. My guess would be that it reccomends not using it in z rated tires because of the materials used in constructing the tire. But that's just a guess.
Old Jan 16, 2009 | 01:27 AM
FASTL61's Avatar
i put fix a flat in my tire then all of sudden got mad vibrations..**** built up and unbalanced my tires by alot
Old Jan 16, 2009 | 01:28 AM
thesoulshereaps's Avatar
Sounds like you need to get your tire reseated. My old galant's tire was leakin after I took a corner a little too hard. It was offset of the rim and leaked.
Old Jan 16, 2009 | 01:39 AM
WHITE G5's Avatar
so if a take it to a tire shop and tell then to remount it, ill stop leaking?
Old Jan 16, 2009 | 01:56 AM
tony2toness/sc's Avatar
It should if it doesn't tell them to put a sealent on the outside of the rim lol
Old Jan 16, 2009 | 02:02 AM
madmark's Avatar
if you use it be prepared because some companys wont repair tires that have fix a flat in itt or and substance like that
Old Jan 16, 2009 | 02:03 AM
mrsilent13's Avatar
i used it on my tire....and it slowed the leak by alot...but right after i threw it in...i went for nice long drive...like 70miles and i didnt feel any vibrations just cuz it got spread evenly
if you take it to the shop dont put the fix a flat in it...its highly explosive
Last edited by mrsilent13; Jan 16, 2009 at 02:03 AM. Reason: Automerged Doublepost
Old Jan 16, 2009 | 02:05 AM
Sharkey's Avatar
why can the tire not be repaired, does it have a puncture in the sidewall or too close to it???
the reason tire shops wont repair damages like above is its dangerous, it can cause a blowout at speed. if the tire cant be fixed, it shouldnt be on the car, and fix a flat isnt gonna make it safe.
Old Jan 16, 2009 | 04:30 PM
mkulrey13's Avatar
fix a flat is used to get you from point a to b in extreme manners as you have no spare or cant get it towed. Not used to fix it permanently.
Old Jan 16, 2009 | 04:32 PM
Psykostevo's Avatar
I used it on an 18" SS rim and it worked. You have to drive it while it is kinda flat, and it inflates while you drive and seals the tire. Kinda weird. They say not to use on Z-rated because without any air you're likely to ride the rim.
Old Jan 16, 2009 | 04:35 PM
mcphatty's Avatar
truth!
and whoever said fix-a-flat is explosive, is retarded
Old Jan 16, 2009 | 04:58 PM
tdipowered's Avatar
use a plug...i got a flat in my one of my pirellis 2 days after my car and i plugged it and it has been hella hot and hella cold and it is fine and holds pressure good
Old Jan 16, 2009 | 05:32 PM
mrsilent13's Avatar
Originally Posted by mcphatty
truth!
if you read the can it tells you it is...not only that they give you a label so you can put it on your valve stem and it lets the people servicing the tire know to be careful
Old Jan 16, 2009 | 05:37 PM
invisible's Avatar
Put about 4 ounces of Slime in it.
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
jmelton327
Sep 26, 2015 10:04 PM
