Fresh From Italy! **Photos**
Fresh From Italy! **Updated w/ Installed Photos**
Deleted the whole story, just pics now. . Updated and installed.
I gotta say thanks again to junior at motorsport-tech.
And don't forget your sham-wow for all of your wet needs, because it's not just a sham, it's a sham-wow!!!
Junior could not have represented his company any better, and I will definately be going back to motorsport-tech for some spacers. Just avoid Steve...he's kind of a douche.
I need to give a special thank you to my homie Eric (Ebristol is his sn) for letting me borrow his winter redline wheels that he painted black until they came....yes they are 17's but it still looks hawt
thank you to alex as well, for putting the rim on and lettig me tighten the lugs while he was on a union break
what you do is tell them what bolt pattern you want, and what you currently are along with the offset needed and they will make your adapter. They provide you with the hubcentric rings and new lug studs and all. They will make any bolt pattern basically a direct bolt on
the O.Z.'s are 5x110 stock bolt pattern, I'm soon to be ordering an adapter kit for either 5x114 or a universal 4 bolt pattern, I havent really decided yet.
Here is the link to their website
http://www.motorsport-tech.com/
If your thinking of ordering through them, ask for Junior and tell him that Jordan Singer sent ya. He'll hook ya up right.
Last edited by cobaltguy889; 06-17-2010 at 12:24 AM. Reason: Automerged Doublepost
The reason I want to change the pattern for my drags are: 1. I can get drag rims cheap on a different bolt pattern, 2. I can run alot wider tire because the adapters will change the offset of the wheel allowing me to run alot wider tires without rubbing issues.
