View Poll Results: What size RPF1's would you buy?
17"
19
22.35%
18"
66
77.65%
Voters: 85. You may not vote on this poll
Gauging Interest: Enkei RPF1 wheels in 5X110 bolt pattern
#128
Anywhere from 18x8 to 18x9 gunmetal looks best imo, noticed you were just across the border so could pick up and just pay duty.
Some center caps would be nice too.
#129
#131
There a lots of cars running the RPF1xBrembo combination.
Here's an example of an STi running just that, with an 18x8.5 +30:
FS: (ND) Enkei RPF1 18x8.5et30 - SOLD - NASIOC
This isn't exactly what we are going for, being a 10" wide wheel, but just for conversations' sake:
Also, a 17x9.5 +33 w/ 5mm spacer:
I hate to be a bother, I just don't want to see this opportunity go to waste.
#133
They will be 18s (majority of people want) in 5x110.
I feel like the color will end up being SBC or gunmetal just because the most people will end up agreeing on it.
They also would look great on every car
#135
I agree, since the 18x9 requires a 15mm spacer I would prefer the 18x8.5 if the +30 doesn't require any spacer. Also it looks like the majority is choosing either SBC or Gunmetal (I want bronze), so I vote for Gunmetal.
#136
fyi, .040" is the extreme minimum clearance you need between that wheel, the range of .050-.2 is much more acceptable and safe for an aggressive driver as wheels, suspension flex a lot under hard cornering.
#137
The normal dynamic changes of the suspension shouldn't effect the spacing between the wheel and calliper, since the mounting surfaces of each are not designed to move independently of one another once assembled.
Wheel flex, would, without a doubt. As well as any minuscule play between the wheel hub/bearing/steering knuckle/calliper itself.
I don't have access to any specific numbers, but your suggestion sounds about right.
#141
just ended up finding a company that builds amazing billet adapters to 5x114.3. they are only 15mm thick due to the pockets on the back of the rpf1's inbetween the lug holes. the pockets allow your 5x110 studs to fit with out cutting any part of them off. i went with 18x9 +35 which requires a 15mm spacer with a hub swap to clear the brembos... hense the adapters are 15mm so its perfect
#143
im not really to worried about it but you are right. Motorsport tech in nevada is the place i went with and ive heard nothing but good news and things from multiple people about there spacers and adapters. but would did you use to shave off the 5mm off of your studs?
#145
I also had to trim/grind my stock studs with a 25mm spacer. Only the tips, not any part of the thread. As the spacer gets smaller, more has to be taken off. As you said any smaller spacer seems a little dangerous. Add that to cutting farther into the thread studs required with a smaller spacer. If the wheels aren't sitting completely flush on the spacer/hub... you'll get vibrations and probably have even bigger issues (wheel come loose )
#147
well i switched it to 19mm. guys had a good point. because i like to drive the car hard sometimes, and take it to the track and i dont want to be haveing problems
#148
So with 18x9 +35, your final offset with a 19mm adapter will be +16.
I am running 17x8 +45, w/adapter final offset is +26. It is flush and I had to roll the fenders in the rear to stop the rubbing.
You'll be poking 10mm more than me and with the larger wheel, you will need some fender work to fit them correctly without looking silly. Roll/Pull fenders will be absolutely necessary.
