Hellaflush/Flatlace spacer kit
Old Apr 14, 2013 | 09:57 PM
  #126
breds2k's Avatar
My guess...stressing....guess, is youd have to go with a 1.25" spacer to avoid cutting studs, otherwise go the original route and get spacers with new studs.
Old Apr 14, 2013 | 10:25 PM
  #127
francis89's Avatar
Originally Posted by Sevensix9
Trust me mine is perfectly flush, I can put camber in it and she pokes hard.
-Alex
Is this what u got on your balt now if so im goin to buy this
http://www.ebay.com/itm/4-BILLET-WHEEL-ADAPTERS-5x110-5x114-3-1-00-SPACERS-5x110-5x4-5-5-LUG-/260957734542?_trksid=p2047675.m1850&_trkparms=aid%3D222001%26algo%3DSIC.CURRENT%26ao%3D1%26asc%3D11%26meid%3D6969060810975002728%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D260957734524%26
Old Apr 14, 2013 | 10:33 PM
  #128
iToastie's Avatar
Francis, don't know if you noticed, but that changes your bolt pattern to 5x114.3 from your stock one of 5x110
Old Apr 14, 2013 | 10:41 PM
  #129
francis89's Avatar
Yeah I was actually confused after reading the product now what should I do choose the same bolt pattern?
Old Apr 14, 2013 | 10:43 PM
  #130
iToastie's Avatar
yeah, you want 5x110 to 5x110
that company (seller on ebay) doesnt seem to have them though
Old Apr 14, 2013 | 10:51 PM
  #131
francis89's Avatar
Originally Posted by C_A_D88
Lies!
5 mm spacer
What kind of lugs u used I need a gold color site pls thanks
Old Apr 14, 2013 | 10:56 PM
  #132
francis89's Avatar
got this ones
http://www.ebay.com/itm/5x110-Hub-to-5x110-Wheel-set-of-4-Rim-Lug-Adapters-Hub-1-thick-Billet-Spacers-/160795431019?pt=Motors_Car_Truck_Parts_Accessories&hash=item257027906b&vxp=mtr
Old Apr 14, 2013 | 10:59 PM
  #133
iToastie's Avatar
Yeah those were the ones I was going to order, although 1" is a little thick, I wanted 20mm
Old Apr 14, 2013 | 11:08 PM
  #134
francis89's Avatar
Did u found a 20mm and was
It for your stock wheels what if I got the 1" whats the difference?
Old Apr 14, 2013 | 11:25 PM
  #135
iToastie's Avatar
20mm = .78 inches
So 1" is roughly 1/4" wider than the 20mm spacers
Old Apr 14, 2013 | 11:29 PM
  #136
francis89's Avatar
20mm = .78 inches
Lol yeah i figured but .25 isnt that bad
Old Apr 15, 2013 | 12:25 AM
  #137
Toastie, have you figured if the stock rims would poke or not on 20mm? I was thinkin about that size too but guess ill never know until i try em lol
Old Apr 15, 2013 | 09:10 AM
  #138
breds2k's Avatar
20mm you WILL NEED new studs! your stocks will poke through not allowing the adapter to sit flush.
Old Apr 15, 2013 | 11:03 AM
  #139
iToastie's Avatar
Idk, the ss/sc wheels are 7" wide, right?
I dont see them poking, but they would probably sit flush
Old Apr 15, 2013 | 11:09 AM
  #140
Pitbull2o08's Avatar
Yeah you'd have to buy new studs for those right?
Old Apr 15, 2013 | 11:12 AM
  #141
iToastie's Avatar
Well that's the point of getting adapters... so you dont need new studs. The adapter sits over your studs which you then bolt down, and then the new studs come out from the adapter.
Old Apr 15, 2013 | 11:14 AM
  #142
ahh got ya. So do you need a flatter nut to bolt the spacers down?
Old Apr 15, 2013 | 11:34 AM
  #143
iToastie's Avatar
Yeah, they usually come with whatever adapters you buy
Old Apr 15, 2013 | 04:56 PM
  #144
AARON-SS-TC's Avatar
So, are these spacers safe? And the 1" allows for the studs on a t/c???
Old Apr 15, 2013 | 05:54 PM
  #145
rockSTAR_SS's Avatar
Anybody got pictures of these w/stock SS/TC wheels and pedders?
Old Apr 15, 2013 | 07:12 PM
  #146
breds2k's Avatar
I have seen it with my own eyes, a half inch spacer leave a TON of the factory stud hanging out. The youtube walkthrough video that the guy sent from mywheeladapters.com i believe said to cut the studs, it seemed that WAY too much needed to be cut.
I think ive already posted these but might as show them again:
My buddy darnell cut just a small portion off of his with barely any thread to run 1" spacers.
LNF's on a SC with 1" spacer, needs a smaller tire width just a bit, rolled fenders would probably help.
Old Apr 15, 2013 | 09:40 PM
  #147
iToastie's Avatar
The whole reason I was going to get adapters was so I didn't mess with the stock studs....
now I have to start my whole idea over
Old Apr 15, 2013 | 10:57 PM
  #148
BlackARCA06's Avatar
I just ordered Adapters from motorsports tech, I ended up going with 26mm hubcentric. If anyone has ever seen a HHR SS you know that the wheels are about 1.5-2 inches in from being flush with the fenders. I have cobalt SS/TC rims and that made it worse than it was with the Stock HHR SS rims. Im looking forward to getting them and will give a review on the adapters but from what Ive been told there good quality.
Old Apr 29, 2013 | 10:18 PM
  #149
iToastie's Avatar
Old Apr 29, 2013 | 11:35 PM
  #150
GoodLuckBro's Avatar
In for the future
