Help, lug nut problem...
Old Nov 18, 2006 | 04:26 PM
orangecobalt's Avatar
So I picked up a set of 17 inch rims for my ls. Stock lugs are too big for the holes in the rims and I can't find aftermarket lug nuts to either fit in the rim or thread onto the wheel studs.
Anyone know a the size I am looking for. The biggest socket that will fit in the holes for the wheels is a 14mm. So the hex has to be 14mm obviously.
Old Nov 18, 2006 | 04:29 PM
CTORANGESC's Avatar
They make thinwall sockets for aftermarket wheels, Im sure they will fit
Old Nov 18, 2006 | 05:35 PM
I only found 1 set that fit into the wheels and it was a tight squeeze with the socket (would have tore up the rim) so the thin wall sockets might take care of that issue, but, they would not thread onto the wheel studs.
Old Nov 18, 2006 | 07:52 PM
HatedCobalt's Avatar
go to your local speed shop and ask for 12mm x 1.5 tuner style lugs. they are the ones with the thin wall socket..
DarrenGC
Dec 24, 2021 01:55 PM
Tykuura
Nov 3, 2015 08:58 PM
Tupp
Sep 30, 2015 08:18 PM
royce777
Sep 28, 2015 07:11 AM
