Help with spacers
Old Aug 1, 2011 | 12:31 PM
Pa1s/c's Avatar
Help with spacers
I have MSR 065 wheels that are 18x7.5 and I was wondering what spacers would make the front and back hella flush with no rub. thanks
Old Aug 1, 2011 | 12:39 PM
wongafet's Avatar
what is your offset on those? We've always said there's no for sure way to do this. Being "hellaflush" is your own opinion, how I see it may be different than how you see it, rubbing depends on your entire setup, what suspension stuff you have and wheel size. But judging by a 7.5 MSR wheel you're gonna need a HUGE spacer to make this happen, and if you do that you're definitely gonna need ARP longer studs. We have a while thread with all our cars that's considered "flush" with our specs and setups, use that as an example. The official OCC Stanced thread under wheels and tires.
Old Aug 1, 2011 | 12:42 PM
Pa1s/c's Avatar
4x100 and the offset is 38
Old Aug 1, 2011 | 12:51 PM
wongafet's Avatar
+38 on a 7.5 rim I'm gonna say you're gonna need at least a 10mm spacer to be anything flush. How low are you? @ 10mm spacer you're gonna need studs.
Old Aug 1, 2011 | 12:58 PM
Pa1s/c's Avatar
I'm on H&R springs front gap is under 1/4 in. or less, back is around 1/2 in.
Old Aug 1, 2011 | 01:08 PM
wongafet's Avatar
doubt you'll rub, alot of us are slammed on coilovers and barely rub.
Old Aug 1, 2011 | 01:14 PM
Pa1s/c's Avatar
that being said 15mm? 20mm? 25mm? haha i really don't know what to go with
Old Aug 1, 2011 | 01:15 PM
wongafet's Avatar
trial and error dude, we all had to go through that
Old Aug 1, 2011 | 01:17 PM
Pa1s/c's Avatar
i think ill start with 15mm and go up thanks for the help
SmitBag
Sep 7, 2016 08:05 AM
chefhhr
Oct 26, 2015 10:36 PM
TotalChaos
Oct 14, 2015 06:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
