new shoes for koolaid car (TSW Nurburgrings )
thats fine not all of us can have boring race cars lol
Probably the smallest 19mm if you take 45 minus 19 you get 26 anything below a 50 offset will hella poke with adapters. That's why you can't just run adapters with any rim, they have to be a pretty high offset wheel to not poke too crazy.
You're not gonna get hella poke with adapters just because you run anything below a 50 offset. It also depends on the width of the wheel. If he is running the minimum size 19mm adapter for a final fitment of 18x8 +26 then it should only poke about 3mm in the rear and it looks like a lot more then that in the pics (unless it is just the angle I'm seein it at), and that's the only reason I was wondering what size adapter he is running.
I am french Canadian
have family from around Quebec lol Love Hockey play everyday I can, normally goalie
The adapter is 25mm inch thick or so
have family from around Quebec lol Love Hockey play everyday I can, normally goalie You're not gonna get hella poke with adapters just because you run anything below a 50 offset. It also depends on the width of the wheel. If he is running the minimum size 19mm adapter for a final fitment of 18x8 +26 then it should only poke about 3mm in the rear and it looks like a lot more then that in the pics (unless it is just the angle I'm seein it at), and that's the only reason I was wondering what size adapter he is running.
