Nitto 555r's, need help.
Old Oct 14, 2006 | 10:47 PM
hatrickstu's Avatar
Alright guys so i finally have some DR's on the way, but i need some help. I know the Nitto 555r's i ordered will need to be heat cycled before going to the track, but i can not find any information on the proper way to heat cycle these tires. I believe there are several people on the site running these tires and i could really use some help becuase i want to get the best performance and life out of these tires. Please share whatever actual knowledge, not opinions, you guys actually have and where you got the information from. thanks
Old Oct 14, 2006 | 10:58 PM
hatrickstu's Avatar
noone?
Old Oct 14, 2006 | 11:18 PM
CobaltPerformanceParts's Avatar
Here is a wrietup from a few sites for you.
http://www.tirerack.com/tires/tirete....jsp?techid=66
http://www.discounttiredirect.com/di...eatCycling.jsp
http://www.clubcobra.com/t44347.html
Old Oct 14, 2006 | 11:38 PM
hatrickstu's Avatar
thanks man
Old Oct 14, 2006 | 11:51 PM
Asphalt Assault's Avatar
What size did you order?
Old Oct 14, 2006 | 11:53 PM
hatrickstu's Avatar
245/50/16
Old Oct 15, 2006 | 12:01 AM
No problem hopefully that helps you out a bit. I have always ordered mine heat treated.
Old Oct 15, 2006 | 12:05 AM
Shortbus's Avatar
Originally Posted by hatrickstu
245/50/16
Same size iam running! i have the nitto nt 555
Old Oct 15, 2006 | 12:08 AM
hatrickstu's Avatar
you were actually supposed to get back to me about those remember? haha, how do you like them? what was the improvement in 60 foot, and how you launching them
Old Oct 15, 2006 | 12:14 AM
Shortbus's Avatar
I love em, they work great, (street launches) I havent track tested them yet because i would like to get axles first, so i can do a high rpm launch, but i do lov e em!
Old Oct 15, 2006 | 12:21 AM
and not to get picky but there is a difference. are you running NT555 or NT555R? thanks
Old Oct 15, 2006 | 12:29 AM
hatrickstu's Avatar
yeah there actually is a difference, 555's are not just purpose built drag tires, 555r's are designed to be drag radials, and the 555 r II's are more road course style tires
Old Oct 15, 2006 | 09:55 AM
05_Blue_B10WN_SS's Avatar
I'm running Nitto 555R 245/45R17's I drive on them daily-40PSI... and for Racing... 20 PSI. They work awsome! Not much of a burnout/heat cycle is recuired for these tires to hook well. Obviously, heating them up for say 10 seconds or so will help. You'll love the tires... a huge step up from stock...
Old Oct 17, 2006 | 06:16 PM
victoriaskimmer12's Avatar
I dunno which ones to get I think im only going to get two cuz my back two pirellis are fine... Should i get the 555's 555'r, or 555rII?? Is it ok to mismatch like have two 555's on the front and the same stock pirellis on the back?
Old Oct 17, 2006 | 06:27 PM
hatrickstu's Avatar
why dont you just rotate your stockers? you wouldnt have this issue then. but if you are dying to run better tires up front for daily driving DR's are not the way to go, they have to soft of a sidewall and will wear out to quickly, then again if your rich this probably wouldnt be a problem
Old Oct 17, 2006 | 06:36 PM
you cant rotate the stock ones i tried it and they wobbeled horribly.. i think something about the weight in the tires, it messes up the balancing.. Plus the Pirellis are not that good of a tire mine are humming really bad, the front two are so bald!!! they hydroplane really bad.. But the plain 555's dont seem too bad
Old Oct 17, 2006 | 06:58 PM
hatrickstu's Avatar
dude i dont even have to see your tires to tell you whats going on. that makes no sense that you cant rotate the tires, they are exactly the same. the reason you are getting vibration when you try is because the back tires in all GM fwd cars cup horribly, which is another reason you need to rotate them often. take them off and look at the inside of the tire you will see what im talking about
Old Oct 17, 2006 | 11:41 PM
ok so what do i do?? its too late to rotate them, im gunna have to buy two new tires
Old Oct 18, 2006 | 12:01 AM
hatrickstu's Avatar
live and learn rotate the old ones to the front and burn em up til the treads are even
Old Oct 18, 2006 | 07:53 AM
i think im just gunna make a big christmas list this year.. cuz i dont want 4 bald tires and end up killing myself from hydroplaining..Im either gunna go with the falkens or the 555's, i would get the 555r's but they wont last too long
Old Oct 18, 2006 | 05:29 PM
Just to let ya know, you don't want the 555R's if you drive like an idiot in the rain. They are DR's, not all-season tires. I've driven mine in the rain several times w/ no problem.. you just have to be slow and carefull.
Old Oct 18, 2006 | 07:12 PM
Good point but really with any tire can you say you dont have to be careful. that is why I am going for dry traction. driving in the rain is no fun period. only do it if I have to get somewhere. as for how long the NITTO DR's last if I can get 7500miles out of them I am happy. I expect them to not last. What I expect is to be doing 1.9 or 1.8 in 60feet.
Old Oct 18, 2006 | 07:35 PM
Vaughts05ss's Avatar
I've got the 555's on the front and the stock pirellis on the back and i havent had any problems at all with them. They arent very good in the rain though like other people have said. They hydroplain bad.
Old Oct 18, 2006 | 07:41 PM
3fo893013L's Avatar
I have street Nitto NT555's and they are awesome tires. I will be buying them again along with getting new 17' SS rims for drags tires only the NT01's
225/45ZR17
my setup on the SS right now is the same except on 18' rims. Of course before I do the switch for nice days/track setup i will already have new tires all around for normal street driving.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
Sep 30, 2015 07:22 AM
Sep 27, 2015 08:53 PM
