Poor white trash and buying tires. What to get?
Old 11-19-2006, 12:23 PM
Spastic Chicken's Avatar
20k miles on my car and GM is saying I need new front tires. I don't really want to go with pirellis again because they don't seem to last very long.
Anyone ever used Toyo Proxes? I really would like to stay under 150-175 per tire.
Old 11-19-2006, 12:28 PM
vB00STw's Avatar
Look for a tire with a high treadwear rating. The only thing is that you cannot compare treadwear ratings from different companies because they are rated differently
Old 11-19-2006, 12:31 PM
Vaughts05ss's Avatar
I would go with the Kumho Ecsta AST's. Their all-season and only $78 each on tirerack.com
Old 11-19-2006, 01:42 PM
I looked at those but i've heard horror stories about the sidewalls on those tires. I've been told they don't hold up.
Can anyone confirm?
Old 11-19-2006, 01:51 PM
budz1065's Avatar
VERY TRUE!!! Each tire company rates thier own tires and the results are distorted. I bet those pzero's are rated much higher on mileage that what people are actually getting.
Old 11-19-2006, 02:05 PM
mcphatty's Avatar
im using the toyo proxes 4, and i love them. great traction on wet roads, great treadwear, and a unique tread pattern that seems to reduce hydroplaning a lot. during the summer they proved to have excellent traction on dry pavement, i would definitely recommend them
Old 11-20-2006, 02:20 AM
07BlackCobalt-LS's Avatar
Hankook has a pretty good 40 something series tire. I used them on my limited edition 2000 Nismo altima I ahd before this car. Never had a car that would hook better at the track. You just dont hear much about them in the racing world. I think I payed 280 or 380 for all 4 tires. But I hear Nitto neogen is the way to go.
Old 11-20-2006, 02:29 AM
repoman's Avatar
Nitto's 555 would be my choice if you don't go back with the pzero's. Should be around 150 a tire
Old 11-20-2006, 02:55 AM
redlineblueline's Avatar
what about nitto nt01
Old 11-20-2006, 03:16 AM
2K5SS/SC?'s Avatar
Try BFG KDW's. They have a 300 tredwear rating and give excellent grip. Those are in or below your price range too.
Old 11-20-2006, 11:31 AM
Can I get them in 215/45ZR18 though?
Old 11-20-2006, 05:00 PM
repoman's Avatar
I would go with a 225/40, but that is just my opinion.
Old 11-20-2006, 06:31 PM
YoAdrian's Avatar
I am getting Hancooks for my next set.
Old 11-20-2006, 10:09 PM
If I go with 225/40s, will that effect speedometer or anything else?
Old 11-20-2006, 10:12 PM
Coblt ss super's Avatar
imma need new tires soon and thinking of getting bfg g force 225/40 would that be a good tire for my car?
Old 11-21-2006, 12:34 AM
EtyrnuSS's Avatar
I read somewhere that the pzero nero's were good, they tested them on a miata, which is lighter than our cars. Did pretty good too.
Old 11-21-2006, 12:38 AM
Tomtwtwtw's Avatar
They will, but the difference is less than 2%. However, if you have access to HPTuners, I believe you adjust the tire size in the computer, so there would be no difference at all.
Old 11-21-2006, 05:17 AM
2K5SS/SC?'s Avatar
The difference in size will barely effect your speedo. It's recommended to keep tires within 3% of the OE tire size for accurate readings. Also check out the Toyo T1R's. max performance tire with a 280 treadwear rating, and they are actually like 2-3 lbs lighter than the BFG's!
Old 11-21-2006, 07:57 AM
The T1Rs are what I was looking at. I've seen them online for like $145ish or something.
Old 11-30-2006, 07:31 PM
Will 225/40s fit on the factory rim? Will the tires rub when I turn?
Old 12-10-2006, 08:25 PM
redss05's Avatar
mcphatty what size are your toyo's? ive been checking on them now for a while and ive been debating on what size, either 225/45/18 or 225/40/18. do you know if ill have a problem with rubbing or anything like that with these sizes? and how is the tread holding up? any help is appreciated
Old 12-10-2006, 08:29 PM
carbombss's Avatar
225 40 18 bfg kdw2 ftmfw
Old 12-10-2006, 08:36 PM
G5GT2007's Avatar
how much bigger of a tire can fit on the rim? like my sunfire they where 195/60/15 and i just got the Fuzion HRi tire put on and they went with a bigger tire so now its got a 205/60/15. and i like how its a wider looking tire. so for the G5 there 205 also whats the biggest number i can go up to that wont hurt the ride of the car.
Old 12-10-2006, 08:38 PM
redss05's Avatar
carbombss... do you have any problems with these tires in bad weather...i live in pa and get some snow every now and then...i heard there no good in snow at all...but you have no problems with rubbing with that size? im not lowered...stock suspension on my ss/sc
Old 12-10-2006, 08:56 PM
carbombss's Avatar
i am h&R lowered an have no rubbing issues at all. as for snow and rain i have no problems here in md great tires great grip. no complaints at all about them
Quick Reply: Poor white trash and buying tires. What to get?
