PSI Winter Tires
Old Nov 21, 2007 | 12:51 AM
jsscooby's Avatar
PSI Winter Tires
So the stockers (2.4 w/17 inchers) recommend 35 psi. I put a little wider rubber on for the winter 215/55/r/16. What would the recommended pressure be? 32psi?
Old Nov 22, 2007 | 09:28 AM
jsscooby's Avatar
Old Nov 22, 2007 | 09:36 AM
REIGN SS's Avatar
Original Hayden Fanatic
What is the recommended PSI on the side of the tire?
Old Nov 22, 2007 | 09:47 AM
jsscooby's Avatar
Max pressure is probably about 40psi. I never go by that. Generally I go by the side pillar on the door. But that is for my stock 205/50/r17. I thinking about just going with 35psi like the stockers because the pressure drops about 1psi for every 10* drop in temp.
Old Nov 22, 2007 | 10:03 AM
steddy2112's Avatar
So you are running 215/55/r/16 on a 17" rim?
Old Nov 22, 2007 | 12:39 PM
jsscooby's Avatar
nono, got a set of VOXX Toscana 16x7 for $60 each
Old Nov 22, 2007 | 12:59 PM
joey26lil's Avatar
the smaller width u go on the tire the better u will be in the winter so id go with a 205/55/16
Old Nov 23, 2007 | 12:03 AM
Infernokron's Avatar
It takes a certain amount of preassure to hold a car up off the wheels. 35 PSI in each tire means for every square inch of tire on the road, 35 lbs of the car is supported. Changing tire size doesn't change how much weight the tires need to hold up. Based on that theory I would say stick with the 35 PSI and watch the tires. If they start wearing in the middle more then on the sides lower the pressure and check again later (my theory sounds great on paper, but it doesn't normally work out quite like that, it's just a good starting place). Being winter tires you probably arn't to worried about maximum cornering performance, so I'd just go with what get's the most tread life.
Old Nov 23, 2007 | 12:40 AM
Katarn_89's Avatar
Actually the pressure inside the tire is the air pressure and has nothing to do with the weight of the car. Go with the pressure that the tires are rated at. The manufacture rates their tires for a reason, they know what they are talking about.....most of the time.....
Old Nov 23, 2007 | 09:23 AM
jsscooby's Avatar
Then the height of the tire would be off, thus messing up the speedo. The tire sidewall spect is measured off the width of the tire. ie: 55 aspect of a 205 width tire would be 112.75mm tall sidewall
exactly, but theses tires are 10mm wider, thus more surface area which I was thinking may mean it requires a lb or 2 less pressure
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
no_ss
Oct 18, 2015 11:58 PM
DANRICKARD
Oct 1, 2015 12:08 AM
