Solstice GXP wheels on G5 GT??
Old Mar 3, 2007 | 03:48 PM
MikeyMo84's Avatar
Anyone know if the solstice gxp wheels will fit right on a G5 GT??? We're upgrading a GXP at my dealership with about $15,000 worth of stuff (ill post pics when its done its gonna be sick) and i might be able to get the wheels off it for my car
Old Mar 3, 2007 | 05:14 PM
saunders1986's Avatar
those are RWD wheels correct?
Old Mar 3, 2007 | 06:40 PM
06VRCoupe's Avatar
if they are the same lug pattern and will fit in the fender well w/o rubbing, i would imagine that they would. I'd check the specs on the wheels first though!
Old Mar 3, 2007 | 07:11 PM
NJHK's Avatar
Doesn't really what drive train they are.
As long as the lug pattern is the same, it should work fine.
Depending on the tire size though, it might throw you VSS slightly off making your calibration for your speedometer a little slower responding but it's nothing severe.
Old Mar 3, 2007 | 07:17 PM
Toronto SS's Avatar
Arent the rear wheels wider than the front ones on those cars? I guess you could buy 4 front rims
Old Mar 3, 2007 | 07:19 PM
NJHK's Avatar
I don't think so...didn't think GM would do anything like that.
Old Mar 3, 2007 | 07:25 PM
eirhed's Avatar
RWD and FWD have different backspacing and offsets
Old Mar 3, 2007 | 07:28 PM
NJHK's Avatar
ok.
Then what about aftermarket wheels? How come there aren't "rwd wheels" and "fwd wheels"?
Old Mar 3, 2007 | 07:42 PM
Red2.4SS/SC's Avatar
ok.
x2
Old Mar 3, 2007 | 07:56 PM
eirhed's Avatar
ok.
They are different, just not labelled as FWD or RWD. Look up the back spacing and offsets for wheels that are on trucks vs. a front wheel drive car...they are different.
Just because they do not have the label does not mean that they are the same. You can believe me or not (better yet, call a tire shop), but I have learned the lesson the hard way with my truck in the past and yes, they were both RWD wheels, the back spacing was off and I could not even get the wheels on my truck.
Old Mar 3, 2007 | 09:38 PM
ok.
there is... most will tell you if its for FWD or RWD
Old Mar 3, 2007 | 09:56 PM
Boosted_SS's Avatar
i believe they are the same lug pattern
Old Mar 4, 2007 | 01:33 AM
CHARGDSS's Avatar
lug pattern is the same...i think the rim is half an inch to an inch wider....all four that is.
my dad has a sky and his tires are wider than mine and thats it. should fit no problem
Old Mar 4, 2007 | 05:43 AM
MikeyMo84's Avatar
lol i guess the only way to find out is to try em on and drive em for a day or 2??
Old Mar 4, 2007 | 10:04 AM
Sicklyscott's Avatar
You'll have to get spacers. I believe they have an offset of around 55 which means they'll hit your struts up front. If you put on some 20 mm spacers on an 8 inch wide tire you should be good to go!
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
DANRICKARD
Oct 1, 2015 12:08 AM
