Solstice GXP wheels on G5 GT??
Anyone know if the solstice gxp wheels will fit right on a G5 GT??? We're upgrading a GXP at my dealership with about $15,000 worth of stuff (ill post pics when its done its gonna be sick) and i might be able to get the wheels off it for my car
Doesn't really what drive train they are.
As long as the lug pattern is the same, it should work fine.
Depending on the tire size though, it might throw you VSS slightly off making your calibration for your speedometer a little slower responding but it's nothing severe.
RWD and FWD have different backspacing and offsets
Just because they do not have the label does not mean that they are the same. You can believe me or not (better yet, call a tire shop), but I have learned the lesson the hard way with my truck in the past and yes, they were both RWD wheels, the back spacing was off and I could not even get the wheels on my truck.
You'll have to get spacers. I believe they have an offset of around 55 which means they'll hit your struts up front. If you put on some 20 mm spacers on an 8 inch wide tire you should be good to go!
DANRICKARD
Oct 1, 2015 12:08 AM
