squeaky brakes
Old Jan 11, 2009 | 06:23 PM
brickloaf's Avatar
squeaky brakes
my car is only 2 years old with 35k miles on it and my brakes are starting to squeak when i brake, should this be happening this soon? is there anything I can do to fix this without replacing the pads?
thanks
Old Jan 11, 2009 | 06:24 PM
bryce712's Avatar
how much brake pad do you have left ?
Old Jan 11, 2009 | 06:25 PM
sport08's Avatar
yes it would be nice to know this.
Old Jan 11, 2009 | 06:28 PM
emiller's Avatar
thanks
If you have 35k city miles, ride them, or slam on them every time you stop they could be worn out. Check the pad thickness like the others suggested.
Old Jan 11, 2009 | 06:34 PM
bryce712's Avatar
https://www.cobaltss.net/forums/show...ghlight=brakes
just something you could look at
Old Jan 11, 2009 | 06:44 PM
FloDamien07's Avatar
if the brakes are still fairly new with some pad left on it you might just want to clean them with brake cleaner.
Old Jan 11, 2009 | 09:25 PM
brickloaf's Avatar
ive been sharing my car with my brother cause hes back from the navy for a few months and i know he likes to show off so hes probably been slamming on the brakes daily.
ill check thickness, and ill probably look in to those rotor/pads since my car has shitty brakes IMO (07 cobalt)
Old Jan 11, 2009 | 09:30 PM
madmark's Avatar
cheap solution if you have bads left. take them off the caliper and set the on the ground (face down) and sand them down on the concrete and put them back on. check your rotors and see if they need resurfaced
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
