SS S/C Rims to date
Old Jan 12, 2007 | 11:29 AM
  #151
Im looking at the ADR wheels, RSL -15 Ricochet wheels in black
here are the specs of them, these will fit correct? just want to make sure
R1575810H42BK 18x7.50 5x100/114.3 42 BLACK
Old Jan 12, 2007 | 03:22 PM
  #152
p7x's Avatar
p7x
No, there're double drilled for 5x100 and 5x114.3 the bolt pattern for the SS and SS S/C is 5x110.
Old Jan 12, 2007 | 10:38 PM
  #153
p7x's Avatar
p7x
A set of some sick wheels IMO, all wheels im considering buying
Foose DF5
Niche Rhine
MKW M71
Old Jan 13, 2007 | 10:14 AM
  #154
EmperorJJ1's Avatar
damn those top 2 are nice
Old Jan 13, 2007 | 11:42 AM
  #155
p7x's Avatar
p7x
^^^ fo sho it just sucks that I want lighter wheels if I was into "show" I would get either in a heartbeat.
Old Jan 14, 2007 | 06:56 AM
  #156
EmperorJJ1's Avatar
where were u able to find those foose dF5 in our offset? i was only able to find the d6
Old Jan 14, 2007 | 12:40 PM
  #157
p7x's Avatar
p7x
not alot of the wheels I post have a 42 offset, if you mean bolt pattern i found them here.
http://www.tiresdelivered.com/advancedSearch.php? page 3 of a cobalt SS search. They have a 34 offset.
Old Jan 14, 2007 | 02:20 PM
  #158
EmperorJJ1's Avatar
whoops bolt pattern is so close to offset (lol not really but ehh im tired)
damn 20s would look nice... if i had the cash right now id do it
Last edited by EmperorJJ1; Jan 14, 2007 at 02:20 PM. Reason: Automerged Doublepost
Old Jan 14, 2007 | 04:01 PM
  #159
p7x's Avatar
p7x
20's would look great but can't find the foose's on a car but here's the rhines in 20's
Old Jan 14, 2007 | 08:09 PM
  #160
xravenwingsx's Avatar
what's the diff between 42 and 45 offset? does it make that much of a difference? stock is 42 on an ss/sc? sorry for the noobie question...but nobody's given me a direct answer anywhere else. :P
Old Jan 14, 2007 | 10:12 PM
  #161
p7x's Avatar
p7x
the diff is just that 3 mms since stock offset is 42 its considered zero offset for an SS S/C. Ideally you want a wheel with the same offset but sometimes not possible. 45 is considered a positive offset.
"Offset
The offset of a wheel is the distance from the mounting surface of the wheel to the true centerline of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true centerline of the rim / tire assembly. This in effect brings the tire in to the fender well more. Conversely, a negative offset means the mounting surface of the wheel is behind the true centerline of the rim / tire assembly. This will cause the tire to stick out away from the vehicle."
So with a rim the same width as stock 7", and a 45 offset, the wheel would be brought into the fender by 3 mms. Which is not much even for a 7.5 width wheel. When you get into 38 offset and 8.5 width wheels you can run into problems. hope this helps
Old Jan 14, 2007 | 10:28 PM
  #162
denny's Avatar
awesome thread Pete. What do you think of the American racing chrome Rogue 18 x 8.5 rims?
Old Jan 14, 2007 | 10:35 PM
  #163
p7x's Avatar
p7x
thanx man, i think they would look sweet. They have the stock wheel styling (fat 5 spoke) but they got a sweet dish on them. I personally think the black ones with the polished lip would look sick on ur car, but thats up too you.
Only thing I would look out for is the fitment 8.5 is pretty wide and with a 35 offset they would be stickin out a bit. Would look SICK with a wide aggressive stance but there might be issues with full wheel lock.
Old Jan 16, 2007 | 05:37 PM
  #164
Smarty Art's Avatar
What is the widest tire that will fit on our car? Comparing the tire width to the offset so that the tire doesn't stick past the fender and it doesn't hit the wheel well. Can we fit a 8" wide tire.
Old Jan 16, 2007 | 06:13 PM
  #165
p7x's Avatar
p7x
8" with 40 42 45 offset is def possible but I cannot confirm a 8.5" wheel. According to tirerack a 8.5" wheel will fit but then it comes down to the tire. Wish I knew more, hope this helps
Old Jan 16, 2007 | 06:18 PM
  #166
denny's Avatar
You seem to be the resident wheel expert around here the 18" have a 8.5 but the 17" are 8 so i may just go with the 17". 225 or 235 /45ZR17 on there what do you think?
Your right the rims painted black with the polished lip do look sick...now I dont know anymore...
Old Jan 16, 2007 | 06:36 PM
  #167
p7x's Avatar
p7x
Im no expert but I am on a seemingly never-ending search for the perfect wheel...... honestly i wouldnt go past 8" width, BUT I would wait for 2fastforyouraSS and rick1217 to get their wheels and tires and see what he has to say on the subject. Nothing like first hand experience. If you can wait, i think thats the best way to do it. 17x8 would fit fo sho but they will look small. If you are ok with that and want to avoid any problems with rubbing 17's are a good way to go.
I would PM 2fastforyouraSS and rick1217 to see whats up. For the Tires.....
18x8.5 best fit = 235/40/18
17x8.0 best fit = 235/45/17 - 225/45/17 is a decent size smaller but you will def not have any rubbing issues.
Old Jan 16, 2007 | 06:37 PM
  #168
M-Dub's Avatar
Yeah, those HRE's are F'in sexy... if you have the coin get those!
Old Jan 16, 2007 | 06:41 PM
  #169
Edubs's Avatar
"17x8.0 best fit = 235/45/17"
That is my ideal setup right there. Nice sub 20lbs wheels with wide tires on them. Would be great for a better feel on the road...
I have yet to find a 17X8 wheel that suites my taste, though...
  #170
denny's Avatar
oh yeah I can wait its for spring time only.
Your probably right that 17" would look kinda small...
I guess I will wait for 2fastforyouraSS and rick1217 input.
thanks buddy.
Old Jan 16, 2007 | 06:46 PM
  #171
p7x's Avatar
p7x
between $500 and $1300 each wheel, they fackin better be sexy
thanks buddy.
no prob man
Old Jan 20, 2007 | 12:28 PM
  #172
p7x's Avatar
p7x
http://www.tiresdelivered.com/searchwheels.php search cobalt ss
Old Jan 21, 2007 | 10:29 AM
  #173
BlilBT's Avatar
Bump for the day!
Old Jan 28, 2007 | 01:57 AM
  #174
p7x's Avatar
p7x
Enkei - WDM
Enkei - FN-18
Old Jan 28, 2007 | 04:11 AM
  #175
SoloZ/SS's Avatar
I like the FN-18 rim. I have allways like multi spoke rims like these.
