Stock SS/TC Wheel Specs
Does anyone know the backspacing of the stock wheel of the top of their head?
I would go out and measure, but I am at my apartment, not my shop, thus no tools.
The reason I ask is, I want to run a 17x8" rim, but I can't seem to find one that will clear the Brembos. Also, what offset would we need to clear an 8" rim? I always get confused when thinking of offset, I am thinking a +45 mm offset, which will also help clear the brakes (am I thinking correctly?).
Thanks guys!
Thanks guys!
FYI-
This has been a while, but I couldn't find the exact answer from GM anywhere so I called Chevrolet. I know people weighed them theirselves, but I wanted to be sure.
The stock wheels weigh 23lbs/wheel. Stright from the horses mouth.
MAN!! I'm glad we got THAT straightened out. Now all we need is somebody to tell us, FOR SURE, what light weight, 17X8 wheel will work with our Brembo's. Preferably without resorting to spacers. We all need help with the straight line traction issue.
Im new the this stuff about tires, but im looking to lighten up my stock 09 ss rim weight as soon as i save up a little bit.
But aren't other factors going to determine actual benefits of a 17x8?
such as: there will be a .5" x the radius of the sidewall increase of weight per tire. (x2 for each tire for both sidewalls)
plus the increased weight of 10mm or rubber on the outside of the tire (assuming you're moving up to 235 width)
plus the increased drag on the tire from road contact with the extra 10 mm of rubber.
all of these things would impact overall weight and gas mileage of the car, correct?
i still think the net change in weight would be negative and would offset the increase road/tire drag.
such as: there will be a .5" x the radius of the sidewall increase of weight per tire. (x2 for each tire for both sidewalls)1
plus the increased weight of 10mm or rubber on the outside of the tire (assuming you're moving up to 235 width)2
3plus the increased drag on the tire from road contact with the extra 10 mm of rubber.
I think even in the most extreme cases, the added area of contact patch and overall lighter wheels should make up for the added weight of the sidewall and width of what you started with.
Point 3 can fall under the same thing as above. The minimal amount of drag added is far surpassed by the added grip you gained.
Lastly offset will not increase or decrease the amount of drag since that has nothing to do with the tire touching the pavement.
DANRICKARD
Oct 1, 2015 12:08 AM
