tire clearance
Old Aug 23, 2007 | 12:50 PM
slvrcobaltscss's Avatar
tire clearance
I know there are quite a few threads out there about what tire size will fit and all that...but I have a question. For those of you who have the BFG G-Force 225 45 18's on their stock rims - anyone else having rubbing issues?? I'm fine when it comes to normal driving (turning, braking, accelerating), but have you guys noticed if you brake hard during a hard turn it sounds like the tires are rubbing. I noticed this last night, wasn't driving fast but almost missed my turn into a parking lot. So I got on the brakes hard and turned the wheel all the way and heard the loud "grinding". I went back and forth in the lot a few times and sure enough it does this on either side, depending on the direction of the turn. Again, I'm on stock suspension and stock rims...anyone else have this with the same setup??
bump...
Last edited by slvrcobaltscss; Aug 23, 2007 at 12:50 PM. Reason: Automerged Doublepost
Old Aug 23, 2007 | 01:32 PM
OrngBalt's Avatar
you sure its the tire rubbing against the body? are there any marks around your wheel wells?
Old Aug 23, 2007 | 01:34 PM
D4u2s0t's Avatar
you sure it's not your abs?
Old Aug 23, 2007 | 01:38 PM
Super_SS's Avatar
i got that tire size on potenza's and sportlines and i dont have any rubbing issue's...only issue i have is when i hit the corner hard the ass feels like drifting so i come out of a corner sliding with the back end
Old Aug 23, 2007 | 06:04 PM
I'm not 100% sure it is the tires...but I'm almost positive. It sounds just like the tread rubbing against plastic, and the sound alters with speed so it has to do with the speed the tire is going...I'm going to look at it more today when I can actually see
well I took a closer look and I'm pretty sure it's contacting at the back of each wheel well, only at the bottom...anyone else have any input/same problems?
Last edited by slvrcobaltscss; Aug 23, 2007 at 06:04 PM. Reason: Automerged Doublepost
Old Aug 23, 2007 | 07:30 PM
D4u2s0t's Avatar
it's the abs. check the fender liners for rubs marks, if there are marks then it's the tire. if there's no marks it's the brakes.
Old Aug 23, 2007 | 08:48 PM
saunders1986's Avatar
AHHHHHHHHHHHHHHHHHHh dont tell me this.... i have em comming.....
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
