Tire help
Old Jun 10, 2007 | 12:21 AM
MTL_G5's Avatar
Tire help
Hey guys, I have a set of almost new winter tires 215/60/15 just sitting in my garage.. I was wondering if they would fit on my G5 ? My current tire size is 195/60/15.
Old Jun 10, 2007 | 12:25 AM
DarkSergeant's Avatar
Depending on your wheel offset, I'd say yes. The ss/sc guys come stock with 215/45/18 and some guys up here have fit up 235's...
Don't trust me though, wait for an LS/LT guy to come in.
Old Jun 10, 2007 | 01:20 AM
spaz's Avatar
They should fit I have 215 55/16 snow tires
Check here for sure
http://www.miata.net/garage/tirecalcold.html
Old Jun 10, 2007 | 01:27 AM
an0malous's Avatar
im not sure about the G5, i know with the ss/sc we cant go below 16inch without modification....
Old Jun 10, 2007 | 02:01 AM
SS BEEOTCH's Avatar
well it should be ok
you'll just have a little bit of an extra lip...it shoudlnt rub either. my biggets concern woudl be the tire rubbing in the front either when you turn the wheel sharply or hit a bumb. best thing you could do is try it.
Old Jun 13, 2007 | 07:26 PM
MTL_G5's Avatar
Old Jun 13, 2007 | 07:33 PM
06G5GT's Avatar
I'm running p205/60r16 winters. They rub on hard turns. Your size is going to be 1/2 inch taller than my size. I'd say you might rub quit a bit.
Old Jun 13, 2007 | 10:10 PM
MTL_G5's Avatar
You mean wider not taller ???
Old Jun 14, 2007 | 10:11 AM
06G5GT's Avatar
No, I meant half an inch taller if you sat each tire side by side. When you run the numbers through a tire size calculator, that's what you get.
The 10mm in width isn't enough to effect anything on it's own.
Old Jun 14, 2007 | 10:13 AM
R&C_rallySS's Avatar
Use a tire size calc. I can't help you to much with the G5 car tires and wheels. As for the SS/Sc I think some people fit a 245/35/19 already.
Old Jun 17, 2007 | 12:46 PM
SS BEEOTCH's Avatar
if you have a 205/60 then the height is 60% of 205 mm. 215/60 will be a liitle taller b/c its now 60% of 215, not 205. what is 60% of 10 mm? 6 mm...there is ur answer.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
