Tire pressure
Old Oct 29, 2008 | 04:40 PM
ace921000's Avatar
Tire pressure
Car is giving me the check tire pressure warning. All tires have around 27-30 psi. Should it be doing this?
Old Oct 29, 2008 | 04:49 PM
PhantomSS's Avatar
need to take off the obama-mod
Old Oct 29, 2008 | 04:51 PM
ace921000's Avatar
What?
Old Oct 29, 2008 | 05:14 PM
DaBuzzard's Avatar
If you have the factory 17" wheel / tire package, your tires should be at 35 psi....so I would say the tpms is doing what it is meant to. Top em up, you will get better handling and mileage
Old Oct 29, 2008 | 05:20 PM
TrevMo's Avatar
Look at the label in the driver's side door jam...tells you what PSI you should be running...
Old Oct 29, 2008 | 08:19 PM
Erod's Avatar
Moderator Alumni
Moved to wheels tires
Old Oct 29, 2008 | 08:26 PM
outtamymind's Avatar
x2 and please don't get the service tpm and check tire pressure messages mixed up like so many people do when they come into the shop i work at. but yes top them up to 35 or even 36 or 37psi and it will go out.
Old Oct 29, 2008 | 09:52 PM
G5Wisz's Avatar
i was just going to post something similar to this...about a month ago my tire pressure light came on and my right rear tire was down to 21-22psi while the others were in the mid 30's, so i filled all the tires to 37psi...ever since theyve all stayed around 35-36 and yesterday the light came on again and the same right rear tire was down to 20psi while the rest was in the 30's. what do you guys think about that?
Old Oct 29, 2008 | 10:49 PM
ace921000's Avatar
Interesting. Got the car few months back and it only has 1100 miles on it and I remember it coming off the lot at about 32 or 33 psi. I will get them filled. Thanks guys.
Old Oct 29, 2008 | 11:35 PM
sounds like either you had/have a nail in your tire causing a slow leak. and if thats not it then i would say its either your valve stem, valve core or the bead is leaking.
and alot of the time's the tech's won't fill them up all the way or their pressure gauge is off by a couple of psi, so when the gauge reads 35 its actually reading 32 or so. as well it also depends on how long the car sat and if it got cold over night.
Old Oct 29, 2008 | 11:38 PM
Red07SSNA's Avatar
.......or you have a "friend" that's messing with ya
Old Oct 29, 2008 | 11:39 PM
that too. but its much more fun to throw 10oz of weight on the wheel and watch them drive away with a massive vibration lol. done that a few times lol.
Old Oct 29, 2008 | 11:48 PM
Blue_Balt's Avatar
The tire sounds like it's leaking a bit. Either that or maybe the sensor is messed up?
How does that tire compare to how the LR looks like?
Old Oct 30, 2008 | 06:34 AM
G5Wisz's Avatar
the RR def is a little softer compared to the others so i dont think its the sensor...last time the light came on i checked the tire pretty good and didnt see any naills or anything. Also how would i be able to tell if the valve stem, valve core or the bead is leaking and what do i do to fix it?
Old Oct 30, 2008 | 10:23 AM
Red07SSNA's Avatar
Easy way to check for leaks is by using some soapy water. Next time you wash the car take some of the water from your bucket and put it around the valve stem -- if there is a leak you'll see bubbles.
....I'm glad I don't live around you
Old Oct 30, 2008 | 07:46 PM
G5Wisz's Avatar
thanks, ill def try it next time i wash the car...I just filled the tire up to 36psi so ill see if it starts decreasing at all.
Old Oct 30, 2008 | 09:23 PM
dead on on the soap its what we use at the shop to check for leaks. well atleast i do and its never failed me.
and ya we only do that if someone is asking for it or special occasions. it also helps when you have a huge shelf full of wheel weights lol. we've done worse though. re-routed our bosses washer fluid line to spray him in the crotch when he uses it.
Old Oct 30, 2008 | 11:07 PM
creedin's Avatar
that is wrong... you mean you need to engage the obama mod
Old Oct 30, 2008 | 11:31 PM
Red07SSNA's Avatar
Funniest one I had done to me so far was a "friend" (co-worker) put long plastic tie straps around my driveshaft (Ford).....makes one-heck of a racket when you get up to speed. Sounds funny at low speed......I was like: WTF?
I got him back....long time after this I put really long tie straps on his truck's drive shaft....funny though...he didn't appreciate it
Old Oct 30, 2008 | 11:38 PM
they never do. and ya you can do the same thing but with stick on weights, put them on the drive shaft. a funny one is my brother took like 10 roll's of painters tape and taped up one of our coworkers car. he didn't like that much either lol.
Old Oct 30, 2008 | 11:46 PM
Red07SSNA's Avatar
I can top that one. When I was a kid waiting at the bus stop to go to school one of the Dads came out to get in his car (VW Bug) to go to work. He started cussing and was looking in the drivers door. Some of us kids went over to look and found somebody had packed the ENTIRE inside of his Bug with wadded newspaper. It was so well packed that even the insides of the doors left imprints in the newspaper when you opened them It took us 15-20 minutes to remove the packed newspaper so he could get in to go to work. Very good job by his subordinates (military guys).
Old Oct 31, 2008 | 12:32 AM
hahaha thats awesome, never heard of that one before. i'll have to keep that one in mind next time i pull a prank on one of the guys at work.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
