tire size with 2.2 on sportline?
Old Sep 5, 2007 | 08:50 PM
rockstarbass1's Avatar
hey guys on my 2.2 i lowered it with sportlines. i currently have 18" rims on i believe 215/35/18 could i fit a 225/40/18 on there or would i have problems? i need new tires and i cnt find anything thats cheap. but that 225/40/18 is wayyyyyy cheaper then any other size for some reason
Old Sep 6, 2007 | 08:30 AM
PlaysWitCars's Avatar
Former Cobalt Owner
you shouldnt have any problems at all
Did you check tirerack and discount tires??
Old Sep 6, 2007 | 08:02 PM
thoes prices were from tire rack......lol 18's are expensive but like i said the 225/40/18 are wayy cheaper for some reason then any other size.
Old Sep 6, 2007 | 10:23 PM
Dispute's Avatar
225/40 18 is more common , i think thats why its cheaper. but the only thing is that its a larger outer diameter tire than what you have on there now so your car will travel faster than what your speedometer says its going (since you travel a longer distance everytime the tire spins around one time).
Old Sep 7, 2007 | 10:32 AM
7Thirty's Avatar
True... but the difference is not going to be enough to make any noticeable effect on the speed. The 18's(225's) will only be a .2 inch difference.. with that small amount u'll be getting a good reading on your speed.... the 215's will throw it off becuz they are actually shorter than your stock tires(if you have 205/55/16's like me its like an inch shorter)
Old Sep 8, 2007 | 06:24 PM
Dispute's Avatar
yep your right the 225 40 18 are closer to the origional tire outer diameter, i diddent even check that, lol. I just knew the two sizes he posted were way different.
Old Sep 8, 2007 | 08:49 PM
xspyder85x's Avatar
i have 17s with that tire size and its no problem.
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
