tire size blues
Old Oct 22, 2007 | 09:13 PM
Spanky's Monkey's Avatar
tire size blues
okay i thought this might be in the wrong thread but it's more 2.2 related then a general inquiry.
i just brought a set of MB Seven X 15" wheels and i'm looking for rubber. i'm sitting on the stock 16" for the sports pack. i hear that if i went with a smaller diameter wheel then stock i will run into problems; mainly braking. my stockers are 205/55-16 and i'm thinking 205/45-15 in rubber.
Old Oct 22, 2007 | 09:22 PM
ChrisAult2004's Avatar
if you drop the aspect ratio it will look like you put 13s or something on there.... to get the same over all diameter you need to up the aspect ratio when you go down a rim size. If you 205/55-16 stock, i would go 205/60-15, or wider at 225/50-15
Old Oct 23, 2007 | 04:14 AM
Black07LS's Avatar
Why are you getting smaller rims? Auto-x?
Old Oct 23, 2007 | 06:03 AM
Mag44579's Avatar
Trying to get winter rubber?
Old Oct 23, 2007 | 06:30 AM
WhiteSSBalt's Avatar
Not a Sebring
205/45/15??
That's gonna look so damn mexican, lol.
(No offense to any Mexicans)
Old Oct 23, 2007 | 06:39 AM
steddy2112's Avatar
Originally Posted by WhiteSSBalt
205/45/15??
Old Oct 23, 2007 | 06:53 AM
rick1217's Avatar
if you want winter rubber, go with a taller tire.... I think the newer cavys that had 15s went with 195/65r15, good size for winter.... low profile tires are crapy in the snow/ice plus you will lose lots of ground clearance going to a smaller diameter tire like that....
Old Oct 23, 2007 | 07:09 AM
Not a Sebring
What he said. Obviously my 19"s come off for winter.....ill take them off after my next meet on Nov 18th. I'm likely gonna buy my moms stock HHR 16"s (when she upgrades to the 17" polished HHR wheels) for winter and keep the 17"s as a backup set of wheels for multiple uses.
Old Oct 23, 2007 | 07:30 AM
TheSheff's Avatar
being from california, it wasn't till recently i relized how much winter sucks!
Old Oct 23, 2007 | 07:36 AM
avro206's Avatar
bingo--thats the size you want. Your speedo will only be out by 0.4&
Old Oct 23, 2007 | 01:02 PM
hobbie2k's Avatar
You think VA winter sucks?
Old Oct 23, 2007 | 01:38 PM
silver06cobalt's Avatar
Oh shut up you act like MN winters are bad...come to Texas...its nothing but feet upon feet of snow each ******* winter...
but 15 in rims with 45 series tires are for one going to look a little rediculous i imagine...and also they are NOT going to be good winter tires like stated above.
At least go with 55 series tires or something larger...Cause such a small wheel with such a small tire is going to do nothing but make your wheel gap look horrible, dropped or not
Last edited by silver06cobalt; Oct 23, 2007 at 01:38 PM. Reason: Automerged Doublepost
Old Oct 23, 2007 | 04:15 PM
i went with the smaller wheel because yes i do race and i'm all about go not show so they don't have to be the sex. i'm not all about the bling and larger rims tend to look off to me. not saying the 15" is any better. i guess all the boyz in da hood turned me off with their massive wheels on anything they can their hands on. anyway i'd prefer the lighter wheel. i cant dump much weight anywhere else as this is my dd and i pack the 3 kiddies in there too. for the record i'm black not mexican and i do appreciate the comments. my stock 16" i'm using for winter the new wheels will be my summer tire. thanks all.
Old Oct 23, 2007 | 04:21 PM
redlineblueline's Avatar
to thread jack here whats the widest possible to go on a 17X7 rim?
Old Oct 23, 2007 | 06:05 PM
rick1217's Avatar
heres a tire size calculator.... enter you factory size and try to find a 15" tire similar in diameter http://www.4lo.com/calc/gearmetric.htm
If you are all about go, I would try going with a 16 or 17" rim and a proper sized tire, thoses tires you suggested first will have about a 4-6+" gap in between your wheel wells and tires.... I dont think they will help at all for performance....they will just make your car look kinda silly(no offence)
kyyankee --- I would say 225/45, maybe a 235/45 or 235/40 but I would only go that size with a +7.5" wide rim...
Old Oct 23, 2007 | 07:01 PM
409Cobalt07's Avatar
tryin not to follow in the steps of kyyankee but i have 17x7.5 and i want to get a bigger tire and i have a 2.0/2.5 tenzo drop and i dont want any rubbing problems. sorry for the jack...
i have 215/40s on now and the fender gap is a little bigger than what i would like...
Old Oct 23, 2007 | 07:39 PM
rick1217's Avatar
well theres an ss/sc guy on here that has 17x7.5 or 17x8 (cant remember) and he is running 235/45/17 with no problems and I believe he has Eibach sportlines, probally just as low or lower than you..... so you should be able to run 225/40s or 225/45s no prob.... I dont think you would really need a 235 wide tire. I think he has the twin screw swap and traction is a problem for him..... but for you, you wouldnt need a big heavy tire, you might lose alittle performance... even go with a 215/45 or one of the two i said above should fit....
Old Oct 23, 2007 | 07:43 PM
an0malous's Avatar
if your all about go and not show, then you should be using a HIGHER profile tire.
you have it backwards bro.
low profile is "bling"
more sidewall will help with launch traction.
Old Oct 23, 2007 | 08:19 PM
DC52NV's Avatar
and you thought those were a better option than the 'WHEELS AND TIRES' section?
moved to wheels and tires section.
Old Oct 23, 2007 | 09:11 PM
sorry DC, thanks for the move. i am gonna go with the larger wall in yoko rubber.
bigdeertz
Nov 17, 2016 09:41 AM
Oct 13, 2015 09:32 PM
DANRICKARD
Oct 1, 2015 12:08 AM
nathan112i
Sep 30, 2015 07:12 PM
