Tire Size and Brand Suggestions Please? will 235/45/18 rub?
#52
Can I put a 235/40/18 Kumho Ecsta MX ??? on my 07 SS/SC
Can I put a 235/40/18 Kumho Ecsta MX ??? on my 07 SS/SC with the stock rims
#53
^^ you will be fine
Here is a quick little explanation on tire sizing to clear some of this up..
Say 225/40/18 for example..
225 is the is the measurement of the tread width (sidewall to sidewall) in millimeters. The 40 is 40% of the tread width. And 18 is the rim size obviously..
Therefore when you widen the tread width, you need to drop the sidewall percentage.
Examples: 205/50/18 & 215/45/18 & 225/40/18 will all stand roughly the same height. Only the tread width will be affected.
Does this make sense?
#54
^^ you will be fine
http://www.tirerack.com/tires/tirete....jsp?techid=46
#55
i got a 225/40/18 on my car and i like it. plus there are way more tire options for that size
the shop i work at buys alot of tires from Tire Rack.
http://www.tirerack.com/tires/Compar...8&startIndex=0
