wheel spacers ????
wheel spacers ????
my friend has a nice set of rims that are 5 X114.3 I believe, I know our pattern is 5X110 could I get a like a 1/2 wheel spacer with offsets to that size or something? there just sitting in his garage and he doesnt want them and I really doo soo, anyway I could get them to fit?
Moved, to wheel/tire.
And you need adapters, not spacers.
If they have a center cap you could have the pattern inserted to fit your car...
https://www.cobaltss.net/forums/wheels-tires-96/wheel-fitment-f-q-stock-wheel-f-q-how-get-wheels-your-cobalt-read-me-8149/
unfortunately for you, wheel spacers don't change bolt patterns.
A wheel spacer sandwiches between the hub and the back of the wheel.
The bolt pattern is the seperation between the bolt holes. (not sure if it is the diameter from the center point, or something else)
So they will not work unless you get some custom work done, which is possible. But a wheel spacer will not help.
Sorry man.
Sorry man.
https://www.cobaltss.net/forums/showthread.php?t=8149
Its the distance, in millimeters, between adjoining holes.
I deal with Adapt-It Wheel Adapters, owned by Gauge Magazine.
Call 317-856-1810 specifically speak to Ginger or Matt and tell them Erod sent you.
