widest tire?
Old Aug 24, 2007 | 03:23 PM
Belto's Avatar
widest tire?
whats the widest tire I can put on my stock 16" ? I still have the stock ones I belive they are 205 wide..
thanx
bump some1 has to know
Old Aug 24, 2007 | 03:25 PM
Super_SS's Avatar
i beleive its 215
Old Aug 24, 2007 | 10:53 PM
Belto's Avatar
I thought you could put like a 225 there,, bc 215 aint that much wider than stock
Old Aug 25, 2007 | 05:06 PM
Belto's Avatar
ok so I guess that the widest is 215 bc thats the only answer I got... thanx super
Old Aug 25, 2007 | 05:45 PM
DrPuttsSS/SC's Avatar
Hi Belto
First off, the racing Cobalts SS/SCs run 245 tires on 17" wheels. But the wheel offset makes a big difference and I don't know what offset they run.
I would suggest measuring this yourself. Kind of a PITA, but turn your front wheels to the stop, crawl underneath both sides and measure how much clearance you have from body and suspension pieces. Figure how much wider you can safely go, then double it. For example if you can safely add 1/2" then 1" X 25.4 = 25.4mm wider tire.
Or, go to some of the tire company sites that list +size options for the car and see what they recommend. The +size system is designed for larger diameter wheels but will still give you an idea how wide you can go.
Hope this helps!
Old Aug 25, 2007 | 06:54 PM
Belto's Avatar
Originally Posted by DrPuttsSS/SC
Hi Belto
Hope this helps!
thanx,, I will check that out
Old Aug 28, 2007 | 05:29 AM
Black07LS's Avatar
225/50/16's should work
Old Aug 28, 2007 | 05:50 AM
REIGN SS's Avatar
Original Hayden Fanatic
Hi Belto
he drives an LS, it has the SS front facia, hence the 16" question
Old Aug 28, 2007 | 12:29 PM
Belto's Avatar
correction I drive an LT//
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
