Will these Saab wheels w/tires fit my Cobalt?
Old Nov 13, 2007 | 04:55 PM
rallyracer's Avatar
Saab Snow Tires on Borbet (aluminum) Rims.
Nokia NRS-T tires, Size 205/50 R16
http://minneapolis.craigslist.org/pts/473293856.html
Old Nov 13, 2007 | 05:02 PM
06_SS_S/C's Avatar
Yeah, those should fit fine. Though your speedo will be off by about 6% or so.
Old Nov 13, 2007 | 05:56 PM
Sergio's Avatar
6% difference is huge... and the 35mm offset is OK, but not great either. You already know the bolt pattern but what is the hub diameter on those wheels? If it turns out to be smaller than stock (65.1mm) you're outta luck.
Old Nov 13, 2007 | 06:03 PM
06_SS_S/C's Avatar
6% isnt that bad...the speedo would read 63.6 when he's really going 60.
I'm guessing these are narrower than the stock wheels since they are only 16" wheels, probably 6.5" wide, so the offset shouldn't cause any problems.
But ya he is right about the hub diameter. If it is larger you will need to get hub rings.
Old Nov 13, 2007 | 06:15 PM
YellowLT's Avatar
He could get centric rings
chefhhr
Oct 26, 2015 10:36 PM
Turbo6
Sep 24, 2015 04:15 PM
jcalvin1126
Sep 11, 2015 10:24 AM
toledobalt
Sep 2, 2015 01:19 PM
