Will this work? Need expert opinions...
Old Jul 2, 2006 | 11:44 AM
Young Money's Avatar
Okay so I'm looking to get some 18's from Tire Rack and the recommended tire size is 215/40-18...
Now I really want to try to minimize the 4X4 look as much as I can until I get some Eibachs, but will a 225/40-18 tire work as well?
I know basically nothing about this type of thing and just want to make sure... props
$YM$
Old Jul 2, 2006 | 12:03 PM
FLM1's Avatar
I'm not sure if it will work, but the tire you have listed is 1 centimeter wider, which will give the tire about 4 millimeters more sidewall.
Old Jul 2, 2006 | 12:10 PM
patathSS's Avatar
When replacing the stock tires 225-40r18 are often the preferred size because of better tire selection and prices.
Old Jul 2, 2006 | 12:14 PM
jester's Avatar
You could put on 235 or iv heard rumers of 245 but theres some rubbing involved lol.
Old Jul 2, 2006 | 12:21 PM
Halfcent's Avatar
I'm old school
The stock SS/SC tire is a 215/45r18. Your recommended tire of 215/40 is smaller, and being put on a base model suspension, which has more clearance. So it will absolutely fit.
Your requested tire of a 225/40 will also fit without a problem.
Sidewall height of each:
215/45 = 96.75 MM
215/40 = 86.0 MM
225/40 = 90.0 MM
As you can see, the SS/SC stock set up has the overall largest diameter. You next concern is the width. Going up one size width (215 to a 225) is fine. You won't rub. Don't go any higher.
I personally recommend 215 (8.46 inches) on a 7" wide wheel, and a 225 (8.85) on a 7.5".
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
