winter tires on ss/tc
Old 10-10-2009, 02:36 AM
tomj77's Avatar
Well last year i went through winter on the stock summer tires, i made it but dont want to do that again. Got me some nordic (cheap brand but will do) 225/50/17's on my 17" rims i finally found that fit. Looks pretty sick, drive good in the snow we got today, but they rub slightly on the pasenger side front fender at the back of the tire when i turn to a cetain point. Guess i gotta wear em down. Rim and tire fill up the wheel well more than the stock 18's i think id go with a 45 next time. but these will do. a little wear and they wont rub.
just a little warning for guys who get 50's they might rub a little on turning.
Old 11-08-2009, 06:04 PM
Bauer21's Avatar
man, these rims you ended up finding, what were they?
Old 11-08-2009, 06:06 PM
Projekt's Avatar
Msr 068?
Old 11-08-2009, 06:09 PM
Force's Avatar
45 is right aspect ratio to go with for that size... Mine don't rub at all.
Old 11-08-2009, 06:14 PM
DEZZIE41's Avatar
im running 205/55/16
Old 11-08-2009, 06:48 PM
Bauer21's Avatar
i want the cheapest possible rims i can find for the winter. i really dont care how they look.. so what would you suggest? Im assuming no steel rims will fit?
Old 11-08-2009, 06:51 PM
DEZZIE41's Avatar
i got 16inch steel rims from the chevy dealer paid 55.00 for each rim
Old 11-08-2009, 07:06 PM
Bauer21's Avatar
and they fit on a cobalt ss/tc?? over the brembos?
Old 11-08-2009, 07:09 PM
jsscooby's Avatar
nope 17 is the smallest rim that will clear and even them you have to worry about it rubbing the side of the caliper.
Old 11-08-2009, 07:10 PM
Bauer21's Avatar
thought so. so what about 17 inch steelies with a 3mm spacer?
Old 11-08-2009, 07:14 PM
DEZZIE41's Avatar
oo i got a ss sc i have to put 16 but wiht brembos u have to run 17s
Old 11-08-2009, 09:25 PM
Force's Avatar
Depends on the wheel, but it works with a few. I run a 3mm spacer on the front with mine.
Old 11-08-2009, 09:28 PM
jsscooby's Avatar
I've never even heard of 17 inch steelies, but yet I'm always surprised. ss/na rims fit for certain. Thats what I have with no spacer.
Old 11-09-2009, 01:39 AM
Bauer21's Avatar
so ive heard but where in the hell do you find them cheap?
would a tire with a load rating of 91 be ok?
Old 11-09-2009, 09:29 AM
Force's Avatar
If you don't mind driving to the GTA, call up Steelcase Tires N' Mags in Markham. They sold me my BSA wheels for cheap ($140/corner).
Old 11-09-2009, 01:05 PM
Bauer21's Avatar
k thanks,, but about the load ratings on tires? does it matter that the contis are a 92 and this tire would be a 91?
for the load rating i mean
Old 11-10-2009, 04:27 AM
Killswitch's Avatar
If you run them at a higher inflation pressure you might be able to get away with it, Depends on how "properly" the tire shop your at does things. I wouldn't recomend it though
Old 11-10-2009, 09:44 AM
Bauer21's Avatar
alright thank you very much.. so you'd stick to 92 or above
Old 11-14-2009, 10:51 PM
V8Rumble's Avatar
91 will be fine
06MetallicBalt
08-17-2021 03:40 PM
bigdeertz
11-17-2016 09:41 AM
RaginChopsuey
10-27-2015 01:27 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
DANRICKARD
10-01-2015 12:08 AM
Quick Reply: winter tires on ss/tc
