Xxr 527
Old Aug 2, 2012 | 09:30 AM
MP Cobalt's Avatar
Xxr 527
Anyone rock the xxr 527 rims on there car? I'm gonna get redrilled hubs, so they say they'll fit 5x100 and 5x114.3 by what the site says. But i have no idea what offset means and all that crap so someone that does please tell me what the difference in +25 and +35 is? also which size tire should i rock ?
Looking at these:
XXR Wheels: 527 17x8.25 Chromium Black Rims
or
Old Aug 2, 2012 | 10:43 AM
he does in 4 bolt
Errday X DSMastery - YouTube
Old Aug 2, 2012 | 10:49 AM
Omnigear's Avatar
them the volk ce knockoffs?
Old Aug 2, 2012 | 10:53 AM
MP Cobalt's Avatar
dang I like them, to bad you really cant see the concave of the 25 offset but i dont have any idea what it means hahaha
Old Aug 2, 2012 | 11:38 AM
Omiotek's Avatar
I run a 18x8.75 35mm offset fits fine.
Old Aug 2, 2012 | 12:18 PM
stock offset is what +42
so +25 pushes the center of rim farther from the hub, the lower number helps fit those wider rims
also with that offset u will be looking at some poke or too much for your taste
concave is found in 10in and wider
u can get some sure but its not as noticeable
i would say measure your stock setup for clearance and compare to your future setup
the rim needs to be able to clear the strut, are u planning to do coilovers or just springs?
u can probably do a 235/40/17 if not on coils.
Old Mar 27, 2013 | 09:41 PM
ChevyBoi89's Avatar
Not to bump something almost 8 months old...but on a 17x8.25 not the 8.75 will +25 poke?
Old Mar 27, 2013 | 10:21 PM
there will be some poke
Inner Clearance: 1.13mm more
Outer Position: extend by 32.88mm
Diameter difference: -1.22" (-4.99%)
i inputed the stock ss/sc wheels 18x7 +42 215/45/18 and 17x8.25 +25 235/40/17
so the wheels willl be pushed out 32.88mm from the hub or from the stock offset
Old Mar 27, 2013 | 11:38 PM
ChevyBoi89's Avatar
Will 35 be flush then? Or sunken in and ill need spacers to make flush?
Old Mar 28, 2013 | 01:03 AM
+35 will sit better if u require a little more fitment of flush you can add
5mm spacers. I can imagine the rear will be flush
Old Mar 28, 2013 | 01:12 AM
Omiotek's Avatar
with 245s the 18x8.75 sit flush... with smaller tires good luck.
Old Mar 28, 2013 | 01:48 AM
ChevyBoi89's Avatar
So 5mm spacers in the front to make it 30 offset will be flush. And rears 35 will be flush? Also im looking at running 235/45/17's. My car is automatic. So I cannot slam it without axle bind. But I have coils (Stance) I'll be good this way? I just wanna be 100% before purchase
Old Mar 28, 2013 | 01:54 AM
Omiotek's Avatar
YOut need to have 5x114.3 Bolt pattern
Old Mar 28, 2013 | 02:01 AM
ChevyBoi89's Avatar
I got that part already lol
I just need help on width and offset to be flush. Small poke at the most.
Old Mar 28, 2013 | 08:28 AM
Omiotek's Avatar
you will need spacers if you wanna poke. like i said i run 245 40 18s they are flush but they are big tires. i had to roll and do a tiny pull out back to get the rears to clear
Old Mar 28, 2013 | 12:28 PM
ChevyBoi89's Avatar
And u also said u are 8.75 inches wide. Im looking at the 8.25 wide ones. As in 17's thats as wide as they come
Old Mar 28, 2013 | 03:53 PM
Omiotek's Avatar
oh your getting 17s...
Old Mar 28, 2013 | 04:28 PM
ChevyBoi89's Avatar
Yup
breds2k
Nov 16, 2013 04:28 PM
GoofyBalt
May 21, 2013 08:10 AM
Cobaltssreddevil
Wheels and Tires
24
Mar 13, 2013 08:31 PM
Steviodaddio
Wheels and Tires
53
Dec 12, 2012 02:36 PM
corey_osu10
Wheels and Tires
14
Jan 7, 2012 02:52 PM
