ZZ Performance ZZ Performance is a proud Supporting Vendor
Advised on the first upgrade mod!!
Old Jun 14, 2015 | 10:49 AM
Phonso's Avatar
 I have a couple questions if someone can help me out I really would appreciate it.
How much horsepower do y'all think that I will get when I install a 2.7 pulley with 80# pound injectors with a smaller belt and a Sports performance radiator. Also a header/down pipe with srs type-r1 catback exhaust system. However I've been doing my research about running a 2.7 pulley with a smaller belt that you have to have secondary reservoir and a dual pass.
Old Jun 14, 2015 | 10:50 AM
Psykostevo's Avatar
Dual pass is a highly recommended mod.
Old Jun 14, 2015 | 10:52 AM
Phonso's Avatar
Thank you I appreciate that!!
Old Jun 14, 2015 | 11:03 AM
Blairwolf's Avatar
Really need more information to gauge what you would put down. Typical stage 3 cars put down 250-260 on pump. Are you on E85 or pump gas? You won't need 80's on pump. You would get a better idle out of 60's. Are you getting a custom tune or canned tune? Also what is done to your car currently.
Old Jun 14, 2015 | 01:25 PM
Phonso's Avatar
I currently have just a normal set up on the car for a 2006 Chevy cobalt SS supercharge 2.0 L Engine. For gas I'm using premium and for the tuning once I find a decent spot in Maryland I'm going to it.
Old Jun 14, 2015 | 02:10 PM
Blairwolf's Avatar
I don't know of anywhere in maryland, but SMG Motoring is in Mass. Since your car is stock have you read the LSJ modification guide? It is a sticky in the 2.0 LSJ performance section.
Old Jun 14, 2015 | 09:36 PM
260 or so whp if your car runs well, is tuned well and you can keep your intake temps down. Definately add a dual pass and option b to your setup. Really these cars should have those mods on the stock pulley.
And no intake? Look into the 'stock airbox mod'.
Old Jun 15, 2015 | 07:31 AM
Staged07SS's Avatar
Administrator
Administrator
No one can really say what you are going to make....
Go check out the official dyno thread on here, and get an idea.
Efficiency is key.
Old Jun 15, 2015 | 11:51 AM
Phonso's Avatar
Thank you
Phonso's Avatar
No one can really say what you are going to make.... Go check out the official dyno thread on here, and get an idea. Efficiency is key.
Thank you
Old Jun 15, 2015 | 11:52 AM
Phonso's Avatar
260 or so whp if your car runs well, is tuned well and you can keep your intake temps down. Definately add a dual pass and option b to your setup. Really these cars should have those mods on the stock pulley. And no intake? Look into the 'stock airbox mod'.
Thank you.
Old Jun 15, 2015 | 11:57 AM
Haven07's Avatar
Exhaust mods help a lot too. Like staged said efficiency is key with these cars.
Old Jun 15, 2015 | 02:41 PM
double clutch's Avatar
I like this guy. Hes very polite
Old Jun 17, 2015 | 06:53 PM
CobaltSS 16's Avatar
go with 60# injectors for pump gas
go with 80# injectors if you're gonna run e85
Old Jun 17, 2015 | 07:15 PM
Phonso's Avatar
go with 60# injectors for pump gas go with 80# injectors if you're gonna run e85
Thank you .
Old Jun 17, 2015 | 07:20 PM
Olybaltss's Avatar
I would recommend grabbing a tuner from this forum though, they can remote tune you if you have the cable needed. Most don't recommend going to a shop for a tune UNLESS they are familiar with LSJ/LNF.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
dieGone
Oct 1, 2015 06:27 PM
OPCrer
Sep 27, 2015 08:11 PM
