ZZ Performance ZZ Performance is a proud Supporting Vendor
fuel pump rewire
Old Jan 28, 2013 | 08:06 AM
Tjolley's Avatar
fuel pump rewire
I'm not here to bash anybody about anything I'm just here to shed some light on what I found. I got stuck about 100 miles away from my house because of this. I've been using this kit for about 6 months now so I know it was not something that I did wrong during install.
Old Jan 28, 2013 | 08:35 AM
Tjolley's Avatar
I would like to know why the 20 amp fuse did not blow before the relay melted
Old Jan 28, 2013 | 01:09 PM
Vander Nars's Avatar
what does the rewire pump do? im assuming helps with fuel delivery.
Old Jan 28, 2013 | 01:14 PM
EmperorJJ1's Avatar
um why would you use an audiopipe relay?
Old Jan 28, 2013 | 01:24 PM
briank6102's Avatar
That is the relay it comes with.. Pump rewire is suppose to increase the voltage to the pump for higher fuel delivery at high rpms I believe
Old Jan 28, 2013 | 01:28 PM
briank6102's Avatar
Also my rewire kit came with a 30 amp fuse!
Old Jan 28, 2013 | 01:29 PM
CCrunner84's Avatar
Interesting, I'll have to check mine, have about 30-40k on the rewire with a DW300.
Old Jan 28, 2013 | 01:36 PM
EmperorJJ1's Avatar
well if it makes you feel any better thats probably not a 40a relay. you should pull it apart and check to see what kind of relay it actually is. then go buy a bosche one
Old Jan 28, 2013 | 02:10 PM
Tjolley's Avatar
It says 40amps on it
Old Jan 28, 2013 | 02:50 PM
CannonBalt's Avatar
No ****... My car isn't starting and throwing a lean code, i have this done.. Im so checking this
Old Jan 28, 2013 | 03:03 PM
CannonBalt's Avatar
What were the symptoms?!
Old Jan 28, 2013 | 03:06 PM
OneCOLDBIZL272's Avatar
Short to ground
Old Jan 28, 2013 | 03:26 PM
CannonBalt's Avatar
I meant your car.. Lol. Lean code? Etc
Old Jan 28, 2013 | 03:46 PM
There really wasn't any really. I had a sputter right before it stopped working... Smelled burnt plastic, then five mins later the car just died.
Old Jan 28, 2013 | 04:31 PM
Tjolley's Avatar
Same here
Old Jan 28, 2013 | 04:40 PM
CannonBalt's Avatar
I never smelt burnt plastic
Old Jan 29, 2013 | 01:50 AM
EmperorJJ1's Avatar
you opened it up?
Old Jan 29, 2013 | 06:55 AM
Tjolley's Avatar
you opened it up?
no it says it right on the front
40A/200v
i think its this i tosed it in the trash already.
What's weird is the relay got hot but the wiring does not.
I did a little looking around and found that there is a momentary relay and a constant relay.
Momentary relay meaning nitrous control or something that is used for a very short amount of time.
Constant relay well that explains itself it is meant to run constantly like a fuel pump.
And the way they explained the momentary relate failure was exactly like this 1 it would end up melting under a small load before it pops the fuse.
Old Jan 29, 2013 | 10:04 AM
ebristol's Avatar
Is this an O or a Z product?
Old Jan 29, 2013 | 10:21 AM
freakta's Avatar
Interesting
Old Jan 29, 2013 | 02:10 PM
Tjolley's Avatar
Z
so tonight i will be taking it total off my car and tossing it in the trash
Old Jan 29, 2013 | 02:18 PM
They are both Identical, mine was a z as well. I was just pleased it didn't take anything else out with it. Only the re wire got messed up. I think mine was a lil more on the toasty side that yours " T". Ill have to take a pic.
Old Jan 29, 2013 | 02:26 PM
No pics of the relay I through that in the trash long ago. It was a hot mess. It didn't look anything like how it started.
Old Jan 29, 2013 | 03:14 PM
EmperorJJ1's Avatar
40A/200v
right but theres a good chance that that 40a relay wasnt actually a 40a relay. audiopipe is a shitty brand meant to run car stereo equipment. im sure whoever made the fuel pump kit just looked into the cheapest realy they could find and would never pop it open to even attempt to see if it was actually a 40a relay. I just wanted you to check becasue if it was a 10a or whatever relay in all actuality then you could spend the 5 bucks or whatever on a new relay and that would probably be the end of it assuming those wires arent fucked now
Old Jan 29, 2013 | 07:11 PM
briank6102's Avatar
I will check.mine now.. give me 5 min
