ZZ Performance ZZ Performance is a proud Supporting Vendor
is this a new intercooler pump?
Old Jul 23, 2010 | 09:10 AM
scotch89's Avatar
http://zzperformance.com/cobalt_ion/...1187&catid=143
it looks like it would be a replacement for the IC pump. unless it's actually is the water pump. any info on it?
Old Jul 23, 2010 | 09:13 AM
coopercharge's Avatar
That is new ic pump however you can get it cheaper from OTTP 114 compared to 199. They are direct replacement Bosch pumps same make and model as ours.
Old Jul 23, 2010 | 09:53 AM
scotch89's Avatar
well whats the diffrence betwwen this and that one? is it suppose to work after the car shut off....ill post what they say
they say.
"Frees up HP by running the water pump off of an electic motor instead of the cars. Helps a lot with top end power.
Allows engine cooling with the car off."
Old Jul 23, 2010 | 09:55 AM
HunterKiller89's Avatar
they say.
its a water pump for engine coolant, not the heat exchanger system. It frees up horsepower because the stock pump is driven by the engine.
Where are you reading that quote by the way...when i click the link, all i see is this:
"Davies Craig EWP electric water pump - Gen3 (EWP80)" along with the price and picture
did you even click on the link? You're WAAY off...
Old Jul 23, 2010 | 10:08 AM
That I was. I assumed that it was the bosch pump as I can not view ZZP's site at work I forgot about the craig davies pump they sell. ZZP also has a stock replacment pump for 199. OTTP is 114. My bad lol
Old Jul 23, 2010 | 10:15 AM
scotch89's Avatar
http://zzperformance.com/cobalt_ion/whatsnew1.php?id=52
Old Jul 23, 2010 | 10:24 AM
gotcha. no worries! lol
thanks. i didnt check the coming soon section
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Sep 27, 2015 08:53 PM
