A tale of something cool and a shop that pwnd ZZP
Supporting Vendor
An issue with the shop we used to deck the block with a ultra fine finish.
Welcome to Facebook
thoughts?
At ZZP we couldn't get past 700 engine HP on the block. So we changed the block design using some technology from one of our guys experienced in high HP Honda racing. GMR tried a similar approach but they messed on in part of the process causing the cylinders to distort. ZZP has engineered around this and we should be shipping 1000 HP capable blocks this spring.
A block we tested to failure. Sleeve let go, cut in half we found an internal crack as well. Also shown is a new ZZP block ready to go where no Ecotec's on this forum have gone before
Welcome to Facebook
thoughts?
is this an entirely new closed deck casting for an ecotec? sand or foam cast?
or is it how the honda guys do and you filled the deck? pretty common in the high hp honda stuff
just stop, please
just stop, please
Last edited by sundevil07; Jan 26, 2011 at 06:55 PM. Reason: Automerged Doublepost
I had my fan turn on at 180-190*, because I found some parts of the block where at 217-228 at stand still, At full boost 240-270- during a dyno run. (thermal gun)
Foam cast is porous, its known to crack in high boost and extreme heat applications plus it's way cheaper to fab the foam cast when compared to a sand/glass cast product.
As for a sand/glass cast product, it is not as porous and it will last much longer. Plus it's known, not to crack as easily than a foam cast product but it cost much higher.
I was going to make a aluminum billet LNF block from Nelson Race Engines, they told me the R&D cost is around $9-14k that was everything from engineering to production. I was going only make 10 blocks to sell. My over head was $3k each minimum.
As for lost foam cast, I got 19 bids from all over the world, the cheapest was from china & brazil each foam cast block was around $1700 - $2600 each. Here in the US, it was $1900 - $2900 each.
Also for sand/glass cast, each one was around $2700 - $3600.
