ZZ Performance ZZ Performance is a proud Supporting Vendor
A tale of something cool and a shop that pwnd ZZP
Old Jan 26, 2011 | 11:58 PM
mrbelvedere's Avatar
good stuff
Old Jan 27, 2011 | 12:27 AM
Omnigear's Avatar
Originally Posted by chrisjaldin
and what would be the price for a 1000hp capable block?
ray bates makes em for drag racing
Old Jan 27, 2011 | 12:47 AM
SSlobalt's Avatar
Looks like it has been decked quite a ways and there are a lot of differences on the block at the bottom of the pic.
Old Jan 27, 2011 | 08:50 AM
Ryan@zzp's Avatar
Originally Posted by Zooomer
An issue with the shop we used to deck the block with a ultra fine finish.
Welcome to Facebook
thoughts?
At ZZP we couldn't get past 700 engine HP on the block. So we changed the block design using some technology from one of our guys experienced in high HP Honda racing. GMR tried a similar approach but they messed on in part of the process causing the cylinders to distort. ZZP has engineered around this and we should be shipping 1000 HP capable blocks this spring.
A block we tested to failure. Sleeve let go, cut in half we found an internal crack as well. Also shown is a new ZZP block ready to go where no Ecotec's on this forum have gone before
Who's block is that?
Old Jan 27, 2011 | 09:09 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
yumnnnnnyyy
:drool:
Old Jan 27, 2011 | 09:11 AM
Kahless's Avatar
nice but how many people are running into problems where 700hp is breaking the block and they need a 1000hp capable one? id like to shake that mfs hand to dd a 700hp fwd balt. i can understand for you guys since youre a shop and play around with stuff that makes that kinda power.
Old Jan 27, 2011 | 09:13 AM
KnightSS/TC's Avatar
I like
Old Jan 27, 2011 | 10:49 AM
BYT*SS*TURBO's Avatar
Did you do the Liquid Aluminum filling method?? WRITE-UP DIY BLOCK FILLING
We did this once on a Honda block but weren't pressing it over 700whp. It held 582 just fine tho with that method and Rods/Pistons/Bearing swapped. Pretty inexpensive motor build really!
Interested in the details tho
Old Jan 27, 2011 | 11:22 AM
very interesting byt
Old Jan 27, 2011 | 11:30 AM
There's looks different tho, so Im curious as to what they did there Closed Deck >
Old Jan 27, 2011 | 12:17 PM
  #36
1971/2009 Chevy's Avatar
due to a lack of F&F quotes
“More than you can afford, pal! Ferrari!”
Old Jan 27, 2011 | 12:24 PM
  #37
Alpha_SS's Avatar
Originally Posted by gone_in_10_sec
Foam cast is porous, its known to crack in high boost and extreme heat applications plus it's way cheaper to fab the foam cast when compared to a sand/glass cast product.
As for a sand/glass cast product, it is not as porous and it will last much longer. Plus it's known, not to crack as easily than a foam cast product but it cost much higher.
FYI, lost foam casting IS a type of sand casting.
I think you are confusing the term 'sand casting' with 'green sand' casting.
With that said, GM uses lost foam casting over green sand casting, because it produces a more uniform (and therefore stronger) part, with tighter tolerances and a better surface finish.
Hopefully that debunks some of the myths surrounding process used to make the Ecotec block.
Old Jan 27, 2011 | 12:40 PM
  #38
gone_in_10_sec's Avatar
Yup your right, I did forget to mention there both the same process. Thanks for looking out..
Here's the link to ZZP LNF/LSJ Block
Old Jan 27, 2011 | 12:47 PM
  #39
Alpha_SS's Avatar
No problem.
Old Jan 27, 2011 | 12:50 PM
  #40
Ryan - is this something you guys where working on last year? I did see the link in the LSJ section but I wasn't sure if you guys were working on this for the LNF platform??
Old Jan 27, 2011 | 01:58 PM
  #41
csementuh's Avatar
The link to ZZP is for their crate engines and does not detail or show prices for the additional block fill.
How much extra is this process, or will it be included in the regular engine?
Old Jan 27, 2011 | 06:57 PM
  #42
HunterKiller89's Avatar
thats not what theyre building.
Old Jan 27, 2011 | 08:34 PM
  #43
Cobalt_Daddy's Avatar
now you just need to make a 1000hp capable transmission lol
Old Jan 27, 2011 | 11:00 PM
  #44
Matt M's Avatar
Here's a pic of a supposed "pourus block." In the middle of the pic you can see a crack in an area that should not be stressed from horsepower. Where the arrows are, the crack goes all the way through the wall.
Old Jan 27, 2011 | 11:08 PM
  #45
cobaltR's Avatar
click
Old Jan 28, 2011 | 12:55 AM
  #46
Thank you, thank god i didn't go with foam cast. Sand casting a little more money but at least I don't have to worry about any parts I produce not cracking.
Old Jan 28, 2011 | 01:09 AM
  #47
Devcon is wicked stuff.. made interesting stuff out of it.. especially stuff that goes bang.. all in the name of science.. hehe..
Old Jan 28, 2011 | 05:03 AM
  #48
freakta's Avatar
subd for later, should be a great year for the cobalt
Old Jan 28, 2011 | 06:22 AM
  #49
INFE's Avatar
Well I know where my money is going to this summer. ZZP I'm officialy impressed! Put me down for one.
Old Jan 28, 2011 | 05:49 PM
  #50
G11's Avatar
G11
thats crazy!
