ZZP. LongTube Header V-Band size?
Does anybody know the size of the V-Band that comes with the Header? It goes between the Header / Cat.
The Header sounds sick. But have a leak some place. It ideals fine, then it wants to die (but does not), then it ideals fine. There was a leak between the Cat / Catback when I used the gasket supplied by ZZP, but putting the stock gasket (metal) fixed it. So now I am thinking it is coming from the head, or between the Header / Cat (This is where the V-band goes.) But my friend tighten it so much that it bent the thread over. So I am going to start at the head using this.
And so forth.
And so forth.
