Idle Misfires
Old 10-04-2013, 08:31 PM
Harmonically's Avatar
Idle Misfires
I've already searched this topic but haven't been able to figure out the problem. I started off getting idle misfires. Only when coasting to a stop out of gear, or just sitting in traffic. Never under load. Also, it doesn't happen consistently. For instance, I got a code twice on my drive home the other day and cleared it both times with my aeroforce, but the last two days where I had to drive city/hwy for 250 miles I didn't get a single code.
So far I've swapped out my old battery for a new battery (Possibly low voltage?). Didn't fix it. Changed the plugs with NGK's, gapped two steps colder, as I'm running higher boost. Still didn't fix it. Checked for boost leaks, no dice. It runs great under throttle, full boost no problem and pulls just as strong as it did while ago. Mods and tune have been good for over a year and nothing's changed. I don't drive the car hard either.
Mods:
TR-10 Intercooler
Hahn hard charge piping throughout
23 PSI HPtune
CAI
Hahn 3" catless DP
Muffler delete
KY Stage 3 clutch
Any thoughts? My only other thought, which seems to be a long shot, is alignment issues. I know the crankshaft position sensor is what throws the CEL for misfires like this, and I've been getting TPMS errors with the CEL for misfires. They don't always coincide, but 50-70% of the time I get them both at the same time then they go away.
Old 10-04-2013, 08:36 PM
BoSStwick's Avatar
I remember when my Cobalt was misfiring. I tried everything but alter my tune, when I did change it, all my misfires disappeared. Just an idea
Old 10-04-2013, 08:38 PM
YelloEye's Avatar
GM replaced my head citing sticky exhaust valves and a cracked valve seat for my warmup misfires, no dice.
Old 10-04-2013, 08:52 PM
That's my next step. Seems odd though, I've been running this tune forever and haven't had any problems. Trying to figure out other alternatives first.
Old 10-04-2013, 10:51 PM
kzak104's Avatar
put in stock plugs
Old 10-17-2013, 11:04 AM
Originally Posted by kzak104
put in stock plugs
They're still stock plugs, just gapped colder. Still the Iridiums.
Anyways, figured out what it was. I WAS getting spark blowout. The colder plugs solved the random misfire. I also had a coilpack on cylinder 3 go bad. Fixed both and now it runs great.
hacadacalopolis
10-28-2015 06:09 PM
tomj77
10-04-2015 11:39 AM
717ssbalt
10-02-2015 04:01 PM
jimbofug007
10-02-2015 12:06 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: Idle Misfires
