Air/Fuel Ratio for LNF??
#51
Why is your car so rich stock? Everyone who has ever dynoed or tuned their car has seen that it starts at 15:1 in the lower revs and goes to 14:1 then finally to 13.4 at 5500 rpms. Ask Area 47 and Psychostevo. I think your scanner is not reading properly or something because you are the only one who has ever posted an A/F that rich stock. IDK. Ask anyone was has seen the stock A/F while dynoing the TC. It is way leaner than your tuned A/F.
#53
It is a stock file tomorrow I will post the log file and the tune
from 3k-4.4k is 13.6 then from 4.4k to 6.1k it steadily drops to 12.04
Maybe something is not right with my car but it is a stock tune
#54
max power is in the 12.8-12.9 a/f jwhittens scanner isnt messed up because when stevo dyno tuned another guys car on here he was in the 12's at wot also. i have been tuning a couple of cars and i have noticed on the last car i tuned his afr was in the 14's at wot but my stock tune and a couple of others where in the 12's i have been trying to figure out why that cars af was so lean and ours where rich
#55
here for all you people that want to argu with me
This is my stock tune and the tune that was used in the following log file
http://www.datafilehost.com/download-e55ccc2a.html
here is my log file with the tune above
these are HPT files so look if you want but I am not B.S.ing when I said that was my AFR.
#57
For those that don't have hpt here is the afr under wot at these rpm.
1200 - 13.1
1520 - 13.1
1760 - 13.1
2000 - 14.0
2520 - 14.0
3000 - 14.0
3520 - 14.0
4000 - 14.0
4520 - 13.7
5000 - 12.9
5320 - 12.8
6000 - 12.8
Too lean you say? Do some research on direct injection.
1200 - 13.1
1520 - 13.1
1760 - 13.1
2000 - 14.0
2520 - 14.0
3000 - 14.0
3520 - 14.0
4000 - 14.0
4520 - 13.7
5000 - 12.9
5320 - 12.8
6000 - 12.8
#58
Rent me! per hour
Lambda AFR Gasoline AFR LPG AFR Diesel AFR Mehanol
1.10 16.17 17.05 15.95 7.04
1.08 15.87 16.74 15.66 6.91
1.06 15.58 16.43 15.37 6.78
1.04 15.29 16.12 15.08 6.66
1.02 14.99 15.81 14.79 6.53
1.00 14.70 15.50 14.50 6.40
0.98 14.40 15.19 14.21 6.27
0.96 14.11 14.88 13.92 6.14
0.94 13.82 14.57 13.63 6.02
0.92 13.52 14.26 13.34 5.89
0.90 13.23 13.95 13.05 5.76
0.88 12.93 13.64 12.76 5.63
0.86 12.64 13.33 12.47 5.51
0.84 12.35 13.02 12.18 5.38
0.82 12.05 12.71 11.89 5.25
0.80 11.76 12.40 11.60 5.12
do not band aid it. fix the maf.
#60
So area is my car car the same as all the others you have tuned? Or is there something wrong with it? Of course it does not matter anymore because I run a flat 12.8 across the board now but I would like to know what you think about my stock tune.
#61
Rent me! per hour
every single one i have tuned, i have not had to mess with the maf in any way shape or form. the afr is dead on what i want it to be.
stock tune is a stock tune. i didn't see anything major in there to be worried about. however, you did upload the same map twice
#62
My MAF error was only 1% stock and only 2% with my Dejon intake and all other mods. No changes are necessary if you have a Dejon intake. CAIs probably need some MAF tweaks because the distance between the filter and the MAF meter is drastically changed.
#63
#64
I have the hahn intake but my A/F seems to be fine am I ok or do I need to do something since the Maf was relocated
#65
For optimum driveability and performace you should have a tuner check your MAF error %. If it is greater than 4% which I would suspect it is. I would definately recomend tweaking your MAF tables.
#67
A/F spiking lean
So I've owned my 2008 SS for alittle over a year now. It has 3" mpx exhaust turbo back (catted), tuned to 20-21psi, Dejon upper, fmic, and K&N short ram intake. I think that's all lol, just got off of a midnight shift so my mind is in bed already. Car dynoed at 305hp@ wheels and 317ft lbs. in the last 4 months it has been giving me small fits. So I began monitoring a/f. It is spiking down to the lowest I've seen at 10.8 and coming back up to ~12.5. Is there any reason why this would develop? Or could it have always been this way and I never paid any attention? Also another issue, possibly related, from 4-6k rpm (wot) I'm getting a miss randomly here and there. No consistency and this is after the initial low spike in A/F. Be easy on me lol
Please provide me with some insight on these issues.
#69
1200 - 13.1
1520 - 13.1
1760 - 13.1
2000 - 14.0
2520 - 14.0
3000 - 14.0
3520 - 14.0
4000 - 14.0
4520 - 13.7
5000 - 12.9
5320 - 12.8
6000 - 12.8
1200 - 13.1
1520 - 13.1
1760 - 13.1
2000 - 14.0
2520 - 14.0
3000 - 14.0
3520 - 14.0
4000 - 14.0
4520 - 13.7
5000 - 12.9
5320 - 12.8
6000 - 12.8
#74
Because it's not due to it running rich or lean. It is the nature of the beast with direct injected engines.
