Forge bpv
Forge bpv
So 2 weeks ago I was driving and noticed when I got on it that it would only boost to 5 psi and the turbo surged/fluttered pretty bad when I let off (bpv didn't work) I stayed out of boost the rest of the way home, pulled my forge bpv out and the spring almost appeared to be stuck in the piston not allowing it to compress. I had lubed it up this spring before starting to drive it again, and it still had some Mobil 1 grease left on it. I chalked it up to a freak occurance. Next day it drove fine. A day later it was back to the same thing. My tuner said to try my stock one as I checked all my t clamps on the pipes and they all were tight. The stock one hasn't missed a beat since I installed it. So the question is- what could cause the forge one to be doing this, and how many others has this happened to. I know there are a few guys on here with zfr's that still run the stock bpv setup. Sadly I bought the forge one about 3 years ago because I thought it was more durable. In my case i guess I may have been wrong.
Yes they do. It's a metal on metal part with prongs and all that good stuff. It blows off every single time you let off the throttle. I mean its bound to wear sooner or later.
People really mistake how bad the stock bpv is. They work great and on my efr it worked up to 30psi no problems with the right spring. Sure the diaphragm can rip but as everything else on the car they all wear out.
After dealing with these things for as long as I have, I'm personally done. Never again will I recommend for someone to purchase one or "upgrade" to. Yes the stocker has it's draw backs but, I've personally always liked the stock unit. It's clearly not flashy and cool, but it's super reliable and predictable.
45,000km on my forge BOV. Need to lube it I think it's eating the black rubber ring lol. Other than that it's a very long and loud blow off. Sounds very nice for the little $ invested and 5 minute install.
