LSJ valves
Old 06-26-2016, 06:45 PM
315SS's Avatar
LSJ valves
I, like an idiot didn't notice my chain tensioner had not engaged when installing my s2 cams, 82# valve springs, titanium retainers, Viton valve seals and new locks and car had jumped time slightly.
Resulting in what I can assume is a bent valve in cyl #2 rest of cylinders have 120psi compression cylinder #2 has 0psi.
I see ZZP sells stock ecotec valves, turbo tech sells their own valves as well as super tech valves.
Anyone use any of these valves and or have an opinion on which I should go with. Also what's included with changing valves, sleeves?
Any help appreciated thanks, Kevin
Old 06-26-2016, 11:50 PM
ItalianJoe1's Avatar
If you just need stock valves, you can get them anywhere. Rock auto carries them too I believe.
To change them you need to remove the head and compress the spring, remove the retainers and then the spring. You can rent a valve spring compressor that wraps around the head to remove them. Not too hard to do yourself if you're a little mechanically inclined.
There is no reason to change valve guides or anything else if you just bent a valve due to mis-timing.
However, if the timing was off enough to bend them on one cyl, it should bend them on all cyls. Seems odd.
Old 07-06-2016, 09:33 PM
315SS's Avatar
Thx Joe,
I installed comp cams ZZP s2, ZZP 82# springs titanium retainers new valve seals, locks and timing chain about a month ago and that damn tensioner didn't engage all the way I caught it quick hoping no damage to piston we'll see this weekend.
Ended up going with the supertech high nickel stainless valves from turbotech. Cometic head gasket and arp head studs
Old 07-07-2016, 10:36 AM
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by 315SS
Thx Joe,
ditch the cometic head gasket and get an oem head gasket.
nothing but issues with those cometic head gaskets.
the oem gasket it an mls gasket fyi.
315SS (07-29-2016)
Old 07-11-2016, 04:57 AM
315SS's Avatar
Understood, thanks staged and Joe!
Old 07-29-2016, 07:45 PM
315SS's Avatar
Install Mls head gasket dry or copper spray?
Old 07-29-2016, 08:10 PM
Dry, always dry on the MLS ones.
315SS (07-29-2016)
Old 08-01-2016, 10:32 AM
Administrator
Administrator
Staged07SS's Avatar
Should have used the oem mls head gasket.... No silly spray required either.
Old 08-01-2016, 02:48 PM
315SS's Avatar
Was too impatient to ship back the cometic for a oem swap, hopefully doesn't bite me :/
Old 08-01-2016, 10:59 PM
bubba_jay's Avatar
It will bite you...
Old 08-06-2016, 05:38 PM
mrbelvedere's Avatar
the tensioner will not just partially engage it works or it does not work you probably miss timed the engine as for the cometic if you copper spray them they seem to hold
Old 04-17-2017, 11:43 AM
Cobalt_noob's Avatar
What exact brand or atleast could y ou point me in the right direction with the valve spring compressor?! im having a hell of a time!
Old 04-17-2017, 11:44 AM
Thx Joe,
How are the Supertech valves working out for you, i just purchased them myself?
Old 04-17-2017, 07:05 PM
https://www.ebay.com/p/?iid=11231239...pp=true&chn=ps
I have this, you don't need it but I've done a lot of ecotecs so that's what I have. You can use any generic valve spring compressor, the ones they rent at autozone/advance auto that are like a giant C-Clamp work fine if the head is off the car. I like this one because you can use it to change springs with the engine still together, but since you're changing valves the head is gonna be off anyway.
Cobalt_noob (04-18-2017)
Old 05-05-2017, 01:46 PM
07cobaltsssce85's Avatar
I have built head from zip with stage 2 cams and 82lbs spirngs with titanium retainers and I love them.
soundwave132
06-22-2016 12:11 AM
brandon04
04-06-2016 12:53 PM
jetaws6
04-04-2016 04:17 PM
soundwave132
04-01-2016 10:03 AM
Quick Reply: LSJ valves
