The quest for 600whp
#361
Turbo manifold is off getting milled, I'm off vacation and back at school (3hrs away from car) Next time I go back home I will do the ATI, ARP timing bolts and fuel system maybe a pcv set up. Trying to decide what tires to run. In the mean time, bored at school trying to gather more money so I can pass time by ordering parts
#368
lol
nothing will hook unless you setup the chassis and dot radials are not street legal due to their reduced tread depth
listen you need to quit whining and worrying over traction you have not even made 600hp yet and there is no guarantee that you will make 600hp so that bee the case you need to worry about chassis setup more then tires because no matter what you put under it unless the chassis is doing its job then the tires have less of chance to work
watch the video close you may learn something from the honda
#369
It is in the chassis and suspension as much as the tires are, true. A good 90s fbody can lose a fat second or so in the 1/4 from good suspension tweaks alone
Thanks for telling me john, good thing i hadnt decided to run mine on the street.. not that i would anyway, they will do nothing but chuck rocks everywhere
