The quest for 600whp
#606
i have a devils own pump (250psi) and check valve with some line for sale if you want
https://www.cobaltss.net/forums/parts-66/fs-option-b-w-bracket-meth-pump-check-valve-307035/
#607
the stock blower manifold is a good piece and often over looked because it is not cool looking
nicks not putting a blower back on
#609
if its done right its more effective then an air to air setup guys running blow through carbs see 300deg at top of hat and 140deg 1in below the carb running e85 and et wise are just as fast or faster then intercooled setups
I'm not knocking it at all, so don't take it that way. It just isn't my personal choice.
#623
There is absolutely no gain to making the charge pipe bigger than the turbo outlet. All that does is increase the volume that needs to be filled and decreases velocity. As for the intake, the compressor is a 3" inlet, so no real gain going bigger there since it would be quite the feat to smoothly transition from 4-3.
If you have a 2.5" outlet, use 2.5. Simple.
