The quest for 600whp
Old 03-03-2014, 11:42 AM
  #601
SPDDMN36's Avatar
I'm sure doing like Alan.
Isnt this the only way to go?
  #602
InfraRedline's Avatar
It's just different, and people cry at different. We drive saturns, we all are used to the hate lol.
I wouldn't personally run a setup like that on my car, but I can appreciate the idea behind it and the simplicity but effectiveness.
Old 03-03-2014, 11:45 AM
  #603
SPDDMN36's Avatar
I'm pretty stoked to try it out. If i dont like it, ive already been offered an intercooler and custom pipes from a friend of mine.
Old 03-03-2014, 11:47 AM
  #604
574
574's Avatar
In need of a meth kit if anyone's got a used one
Old 03-03-2014, 11:48 AM
  #605
SPDDMN36's Avatar
Same, if anyone has 2
sorry nick...
Old 03-03-2014, 11:50 AM
  #606
i have a devils own pump (250psi) and check valve with some line for sale if you want
https://www.cobaltss.net/forums/parts-66/fs-option-b-w-bracket-meth-pump-check-valve-307035/
Old 03-03-2014, 12:00 PM
  #607
mrbelvedere's Avatar
if its done right its more effective then an air to air setup guys running blow through carbs see 300deg at top of hat and 140deg 1in below the carb running e85 and et wise are just as fast or faster then intercooled setups
the stock blower manifold is a good piece and often over looked because it is not cool looking
nicks not putting a blower back on
Old 03-03-2014, 12:06 PM
  #608
OK lol i was like.. um 600 whp... blower... wut
Old 03-03-2014, 12:23 PM
  #609
I never argued that. I know the facts. I'm also not a drag car that makes 2,000+ HP. I will make baby power compared to a lot of guys around, and I'm not worried about any lag. I've been around plenty of "big turbo" street cars, and have a certain way I wan't mine to be, from the performance, to the looks, to the uniqueness, and extensiveness. Also, I just told my car a long time ago when the meth failed and the motor lived that I would never put any sort of injection on it ever again. I also like to make things really intricate, which is probably apparent lol. Even if I were to run something like that, the piping would be under the engine, which would damn near negate the idea.
I'm not knocking it at all, so don't take it that way. It just isn't my personal choice.
Old 03-03-2014, 12:54 PM
  #610
I did not take it that way I was just explaining
Old 03-03-2014, 12:57 PM
  #611
I know you crazy cat, I know, just making sure. Boys, its almost spring...its almost car season!
Old 03-03-2014, 02:23 PM
  #612
Gds pimpen yo
Old 03-03-2014, 02:43 PM
  #613
armcclure's Avatar
STX dawg
Old 03-03-2014, 05:22 PM
  #614
https://www.cobaltss.net/forums/adva...lsj-tb-154439/
Old 03-04-2014, 06:45 AM
  #615
armcclure's Avatar
There's still a spacer bud
Old 03-04-2014, 08:31 AM
  #616
yup but you don't need 3in worth
Old 03-04-2014, 12:32 PM
  #617
armcclure's Avatar
Stone's mom don't need 3" worth, lucky for you
Old 03-04-2014, 01:01 PM
  #618
lmaorotf
Old 03-04-2014, 05:09 PM
  #619
574
574's Avatar
Alright it's official official, just placed ordered most of stuff needed
Fab piping for intake (3") charge piping (2")
Bov weld on flange
V-band for compressor housing
Still need to order:
weld in maf
maf extension
mini afc
Old 03-05-2014, 10:45 AM
  #620
Just wondering, how come you are only going 3" with the intake and 2" with the CP?
Also I'm just like you, on 8-9 lbs currently Don't know why the hell there is such a small gate spring in there, but that will be solved shortly.
Old 03-05-2014, 10:52 AM
  #621
kdub1492's Avatar
2" with CP is small man, I would look to do 2.75" if anything, and maybe think about a 3.5" intake. Anything bigger gets tough to tune
Old 03-05-2014, 11:04 AM
  #622
I'm building a 4" intake, but I'm not draw through.
Also, I have a MAF extension laying around if you need Nick.
Old 03-05-2014, 11:12 AM
  #623
armcclure's Avatar
There is absolutely no gain to making the charge pipe bigger than the turbo outlet. All that does is increase the volume that needs to be filled and decreases velocity. As for the intake, the compressor is a 3" inlet, so no real gain going bigger there since it would be quite the feat to smoothly transition from 4-3.
If you have a 2.5" outlet, use 2.5. Simple.
Old 03-05-2014, 11:21 AM
  #624
For some reason I thought you had 2.5 or 3" outlet Alan. And I didn't even know Precision made the 5862 with a 3" inlet. I would have thought it was 4" like the 5858.
Old 03-05-2014, 12:30 PM
  #625
574
574's Avatar
My inlet is 3" and outlet is 2" so basically everything alan just said, no point in going bigger. And I'll take you up on that maf extention, pretty sure I'm getting my meth pump from rice
Quick Reply: The quest for 600whp
