LSJ Manifold on L61 (EGR/Air Injection Question)
Old 11-15-2006, 01:24 PM
tonio5555's Avatar
I have in my friend's garage, an LSJ exhaust manifold that I intend to install on my 2.2 L61, both manifolds are off 2006 model years, however with all the talk about this EGR/Air Injection stuff I wanted to know if there was a port for the Secondary Air Injection on my LSJ manifold. If there is nowhere for me to attach the air line going from the intake to the manifold, then what should I do with that line?
tonio5555 is offline
Old 11-15-2006, 01:36 PM
rally's Avatar
You should not install the manifold. If you actually do have Seconday Air Injection then it will severly hurt your car and throw it into LIMP MODE.
And I hate when people say EGR, theres NO EGR on ANY COBALT. EGR is COMPLETLY different than Secondary Air Injection
rally is offline
Old 11-15-2006, 01:47 PM
I'm old school
Halfcent's Avatar
Does your L61 actually have SAI? Are you sure? If it doesn't, then the LSJ manifold will be fine. But to answer your question, no, an LSJ manifold has no provisions for SAI.
Halfcent is offline
Old 11-15-2006, 01:49 PM
D4u2s0t's Avatar
if you have the air injection, then don't use the manifold that doesn't have it...
D4u2s0t is offline
Old 11-15-2006, 04:36 PM
tonio5555's Avatar
My car does have SAI. There connection is there on the air intake box. So I guess I won't be able to use this manifold then... is there anyway I could fabricate a connection for the SAI to the LSJ manifold?
Old 11-15-2006, 04:40 PM
D4u2s0t's Avatar
well, i guess you could drill a hole in the intake, put a mount, and then drill a hole in the manifold and make another mount... it's probably more trouble than it's worth for the extra few hp... i would just wait till they come out with something that works...
D4u2s0t is offline
Old 11-15-2006, 04:46 PM
SilverBalt's Avatar
ihave had mine out.. i was actually the person who found out about this the hard way and cause a big hassle.... there isnt really a way to fab it up, i have looked.. as stated right baout dont bother wasting ur time just wait
SilverBalt is offline
Old 11-15-2006, 06:27 PM
biniecki's Avatar
I have yet to see the difference in the two manifolds. Does someone have pics of manifold that has the SAI and one that doesn't.
biniecki is offline
Old 11-15-2006, 09:05 PM
rally's Avatar
Have you seen the two different manifolds? Because theres definetly a difference.
rally is offline
Old 11-16-2006, 03:46 PM
I'm old school
Halfcent's Avatar
New Sticky!
https://www.cobaltss.net/forums/show...625#post628625
Halfcent is offline
Supercharged06SS
12-11-2022 04:47 PM
DarrenGC
12-24-2021 01:55 PM
06MetallicBalt
08-17-2021 03:40 PM
brandon04
10-21-2015 07:04 AM
10-13-2015 09:32 PM
Quick Reply: LSJ Manifold on L61 (EGR/Air Injection Question)
