my LSJ build :D
Old 05-19-2012, 06:34 PM
  #126
G11
G11's Avatar
So I'm doing something similar to what you are doing...with you changing the compression ratio what are the benefits
Old 05-19-2012, 11:03 PM
  #127
zrated89's Avatar
more power. Its a trade off with timing though. Higher comp better torque as well
Old 05-23-2012, 07:16 PM
  #128
zrated89's Avatar
last package to finish the build
Old 05-23-2012, 10:56 PM
  #129
Joemaster70's Avatar
curious with GMR cams do u need different rockers?
Old 05-24-2012, 07:37 AM
  #130
Administrator
Administrator
Staged07SS's Avatar
No.
Solid lifters.
Old 05-24-2012, 08:14 AM
  #131
zrated89's Avatar
^^This
Old 05-24-2012, 09:00 AM
  #132
Speedytec's Avatar
No.
Solid lifters.
Well, ideally you'd need rockers with 1mm higher mounted ball bearings to compensate the smaller base circle and keep correct valve geometry...
Sadly these do not exist, so solid lifters is 2nd best.
(Maybe you can fit some valve stem caps, but normal caps would need some modding (sides) so they fit inside the rockers...)
Old 05-24-2012, 09:11 AM
  #133
Speedytec's Avatar
Edit:double posting
  #134
shabodah's Avatar
The way the valve stems are nested into the roller followers makes it hard to use any sort of lash cap on the valve. I was looking into titanium valves and the main issue there is that you need a different material at the top of the valve as galling is an issue there with titanium. Raising the valve height would still change the valvetrain geometry on its own, so if the goal was to keep the valvetrain geometry the same, you'd have to do different lash adjusters (solid lifters) and taller valves. I've still been looking for other roller followers with different bearing diameters, but, haven't found anything usable. Thankfully, zrated here purchased my GMR cams, so, I don't have to think about it any more.
Old 05-24-2012, 01:05 PM
  #135
zrated89's Avatar
passed the headache to me
Old 05-24-2012, 01:09 PM
  #136
zrated89's Avatar
i think what i still may be doing is using the oem lash adjusters with the gmrs. Even with the head casting and the way the bore is, we may build the bore up and machine it back down to run the oem stuff, so no shims needed
Old 05-24-2012, 02:13 PM
  #137
shabodah's Avatar
I found my own, different solution in the process.
But, being broke, it'll be a while before I can do anything with it.
Old 05-27-2012, 02:09 AM
  #138
kstorm61's Avatar
Hey Z rated what are u pushing for horsepower these days ?
Old 05-27-2012, 08:58 AM
  #139
freakta's Avatar
^^^ a lot
Old 08-12-2012, 02:18 PM
  #140
zrated89's Avatar
figured id bump this
alot in the build has changed for the better ill update soon. She should be running this coming weekend got the ported and polished head back looks sick
Old 08-12-2012, 02:21 PM
  #141
Melon's Avatar
lookin sexy! how hard was it to do with the motor in?
Old 08-12-2012, 02:33 PM
  #142
carstedt's Avatar
its not hard to do pistons and rods with the block still installed...most people leave the blocks in if they are not sleeving...at least from the builds that i have done
Old 08-12-2012, 05:06 PM
  #143
zrated89's Avatar
it wasnt hard. But me being a tech, i spent alot of time honing the sleeves, cleaning everything and gapping the total seal rings by hand. All tedious stuff. Most that throw pistons in dont hone the block, let alone hone it in car
Old 09-04-2013, 10:08 AM
  #144
hey T how much money do you think this cost you roughly? i'm trying to budget to do a similar build currently
Old 09-04-2013, 10:23 AM
  #145
jrmotosports 88's Avatar
click info is priceless
Old 01-29-2014, 08:29 PM
  #146
GRABBER BLUE MUSTANG GT
Corvettespirit's Avatar
Are you still working on the engine? Lol!
Old 02-01-2014, 05:36 PM
  #147
freakta's Avatar
whatever happened to this?
Old 02-03-2014, 07:19 AM
  #148
Administrator
Administrator
Staged07SS's Avatar
He had a kid.....
Right Kenny??
Old 02-03-2014, 08:19 AM
  #149
Only excuse i can see is hot girlfriend. The kid you can always strap in a bouncy buggy out in the garage
Old 02-04-2014, 03:41 PM
  #150
zrated89's Avatar
lol build has change a WHOLE lot since this lol. I really dont frequent the forums too much anymore. But a sleeved big blore block is going in now on top of my turbo setup
Quick Reply: my LSJ build :D
