my LSJ build :D
Old 02-11-2014, 01:56 PM
  #151
freakta's Avatar
That is a huge change. I'm glad your still at it. How big are you going? What compression are you planning on?
Old 02-11-2014, 02:59 PM
  #152
I see many smashed records coming by a big difference.
Old 02-11-2014, 05:08 PM
  #153
zrated89's Avatar
the block is a bates sleeved 88mm 2.1 that I grabbed from danew. I had to bore it to 89mm because of some surface rust on the sleeves, and had it decked because bates screwed everyone telling them to install the sleeves above deck height, and run a stock mls gasket. So shes 89mm, roughly a 2.23L bore, with custom 10.1 diamond pistons. Head is ported and polished, zzp valve springs, and will be on their stage three reverse split cams. arp studs everywhere, Molnar rods all new bearings etc. On top of my precision 6262 dbbing turbo with the ported sp 4 inch inlet cover. On E85 and planning to run over 30psi of boost. Should make well over 600 whp conservatively. goal is to take the fastest manual trans 1320 time from ryan. Since I already have and still have the fastest sc time
Old 02-11-2014, 06:26 PM
  #154
freakta's Avatar
damn i wish you the best. i hope it surprises you and you make 700whp
im hoping for 350 with my build and a high 13 with a silly trap speed (driver mod needed)
Old 02-11-2014, 06:45 PM
  #155
nathanrogers111's Avatar
in for results
Old 02-11-2014, 07:35 PM
  #156
Got Bewst?
Bluelightning's Avatar
What would the time to beat be? He ran the 9.82 on an auto trans?
Old 02-11-2014, 08:11 PM
  #157
zrated89's Avatar
he ran lows 10s before he switched to the auto
when I say 600, that's a really easy plausible number, im sure shell make higher
Old 02-11-2014, 08:18 PM
  #158
10.9 was your fastest sc time right
Old 02-11-2014, 08:25 PM
  #159
zrated89's Avatar
lol hell no. Unofficially 11.95 was but officially 12.003 is the record
Old 02-11-2014, 08:52 PM
  #160
Got Bewst?
Unofficially 11.95?
Old 02-11-2014, 08:53 PM
  #161
Oh damn
Didnt cmiller do 10.9 o nm he was turbod
Old 03-01-2014, 04:42 PM
  #162
zrated89's Avatar
Unofficially 11.95?
RAN AN 11.95 but the slip printed said none. My tuner Joe and a few guys off the forum witnessed it, but none of their asses was recording
Old 03-24-2014, 06:57 AM
  #163
freakta's Avatar
Any update
Old 04-10-2014, 10:56 AM
  #164
freakta's Avatar
hope nothing happened
Old 04-10-2014, 11:20 AM
  #165
armcclure's Avatar
Bump for a slow car
Old 04-25-2014, 02:38 PM
  #166
zrated89's Avatar
LOL **** you alan. yes just pulled my original crank from my other motor. Its the only part im reusing on the built block. Waiting for my ATI dampner to show up, then the rotating assembly is going to chuck at the race shop to be balanced. Then the block will go back in. currently looking at the southbend stage 4+ clutch as i know the gmp wont hold that power with 50k miles on her and numerous track passes
Old 04-25-2014, 05:13 PM
  #167
He's been busy making another little Kenny lol
Old 04-28-2014, 02:33 PM
  #168
InfraRedline's Avatar
Come on Kenny we need a badass LSJ reppin down in your area! Get to work!
Old 06-03-2014, 04:26 PM
  #169
zrated89's Avatar
just got the rotating assembly back, my ati showed up too. Assembling this weekend
Old 06-03-2014, 04:29 PM
  #170
you said that last week !
Old 06-03-2014, 04:31 PM
  #171
zrated89's Avatar
I did not I said the assembly was going to the machine shop lol
\rhfv 0------cc
']-032d
sd\WcD n71gfr
41h
SEE even little Kenny approved lol
Old 06-03-2014, 09:17 PM
  #172
haha. he has the best of both worlds. dads got boost, moms got *****. little Kenny FTW!
Old 06-07-2014, 05:34 PM
  #173
freakta's Avatar
Hope its going on without a hitchh.
Old 06-08-2014, 09:09 AM
  #174
zrated89's Avatar
https://www.cobaltss.net/forums/2-0l...ctures-310544/
new updates !!!
Supercharged06SS
12-11-2022 04:47 PM
05-28-2022 03:47 AM
06MetallicBalt
08-17-2021 03:40 PM
ineedacobaltss
11-07-2015 02:25 PM
09-28-2015 12:51 PM
Quick Reply: my LSJ build :D
