Wideband issues.
Old 07-27-2015, 06:39 AM
Coballin13's Avatar
Wideband issues.
so the idiot who owned the car before me decided it was a good idea to put the wires through the steering column hole rather then through the grommet, which resulted in all the lines getting wrapped up and torn. So I fixed the boost gauge and oil pressure gauge, but the wideband i can't fix.
I took it all out and wired up the wires where it had snapped off, and plugged it all back in , but it's still not lighting up. Yes it's hooked up to a power source but the gauge won't even turn on. Did it short out the gauge? Or do I just need a new wire? Help would be appreciated thanks.
Sent from my iPhone using CobaltSS
Old 07-27-2015, 10:03 AM
blueLNFftw's Avatar
It probably pulled the wires off of the board inside the gauge itself.
Old 07-27-2015, 10:01 PM
Coballin13's Avatar
So you think I need a new gauge completely
Old 07-30-2015, 09:04 AM
blueLNFftw's Avatar
Yea.
Old 08-12-2015, 07:04 PM
tomj77's Avatar
Either tore wires in gauge or blew gauge if power grounded to steering column. Is there no fuse to check? Idiot could have set his car on fire
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
n20saturn
09-30-2015 12:26 AM
yellow dragon
09-28-2015 09:49 PM
jcarroll53
09-24-2015 07:43 PM
Quick Reply: Wideband issues.
